For the answer to that, you may need to think back to the way things were before the previous ION dispute. Prior to that, Dish carried both east and west national ION feeds, and they were both SD-only. Although ION showed up on the local channel number in the local package for markets that have an affiliate, the Dish-delivered feed was not the actual affiliate, but rather a re-map of the appropriate national feed for that time zone.I wonder why the local ION stations are still running as when Univision was lost, the locals were blocked too.
It will affect every channel that is in the HD or SD category. So, If your channel is an HD channel every HD channel will change to whatever you changed it to. SD, the same way.
I can say that I liked it a lot better when it was PAX. It is funny that after all this time, many affiliates still have call letters that reflect the PAX branding. (WVPX, for example) I guess they couldn't come up with enough plays on the ION name to make it worth changing the call letters again.I can't say that I ever watched ION. That includes when it was PAX.
All OTA channels are listed as HD whether the content is HD or not. That is because the channels themselves transmit in 1080i or 720p, some channels with multiple sub-channels..I get my local ION station only via an OTA antenna.
Then I will not mess with for only an occasional show. It is labelled as HD in the Dish guide, but it is not. The only local ION station I get is via an OTA antenna.
Isn't Buzzr and Comet, Grit, folk Laff, MeTv subchannels?
Of course not. They are networks, and like all other broadcast networks they may or may not be carried in a given area, and if they are, may or may not be on a subchannel or main channel.
Well we can close out this thread Dish and ION made a deal. They're back on.![]()
I thought that was just so Dish would not have to keep track of which subchannels are SD or HD. Providing OTA guide information is not Dish's primary business.All OTA channels are listed as HD whether the content is HD or not. That is because the channels themselves transmit in 1080i or 720p, some channels with multiple sub-channels..
Probably to avoid taking viewers (and ad dollars) away from the local affiliates. If the national feed were competing directly against the local affiliates by providing an HD feed, that would likely lead to Dish being forced to blackout the national feed in markets with a local affiliate. Also, a national HD feed would use up more bandwidth than the SD feed.It would have been better if it was in HD. Why isn't it in HD?
It is a nice Christmas present from Dish.Well we can close out this thread Dish and ION made a deal. They're back on.![]()
Well, if we are going to get nit-picky, Dish most certainly does carry subchannels, in Alaska, Hawaii, Puerto Rico, and the US Virgin Islands. (This is a special requirement for satellite delivery of locals in "non-contiguous states" which is also applied to PR and USVI because they are non-contiguous, even though they are not states. This was part of a trade-off for these areas, since the same law also banned the importation of distant networks to these areas. And for those who were wondering, this was put in place long before Dish got hit with the distant network injunction, and applies equally to all satellite carriers.)Subchannels, which was the question posed, most certainly are not. The fact that the networks listed are (as you note) really should have been an adequate answer regarding if they are subchannels, which again, they may or may not be carried on subchannels in any given area. Which would be irrelevant because (sing it with me) Dish does not carry subchannels and if the national feed is removed, those without an antenna or other provider are SOL.
Metv is only available in markets without it...not like a network at all
Sent from my SM-G950U using the SatelliteGuys app!
For purposes of some of the copyright licenses necessary for satellite or cable delivery of local channels, the term "network" only applies to the four major networks (ABC, CBS, NBC, FOX) or even only to the three major networks (ABC, CBS, NBC) for purposes of which standard to use to qualify a station for the Significantly Viewed List, for example. I prefer to use the term "broadcast entity" to avoid confusion.
