ION network is off from the program guide. Another dispute. Hope when they get it back if they get it back it's in HD.
Like others have said, ION is in HD, in the markets that have affiliates. The same day that the national feed was removed, Dish also added tags in the uplink reports to a bunch of ION affiliates across the country. So, maybe Dish is preparing to use these affiliates as fill-in distant stations for markets that lack an ION affiliate, and simply do without carrying a national feed at all.ION network is off from the program guide. Another dispute. Hope when they get it back if they get it back it's in HD.![]()
The national feed disappeared from everyone, whether there is a local affiliate being carried or not.I think our local ION affiliate switched to must carry and the national feed disappeared. The local is HD and looks good.
Isn't Buzzr and Comet, Grit, folk Laff, MeTv subchannels?You're likely not receiving any other subchannels either, why would this be different?
I don't understand this. If I read it right if none of your local networks broadcast ION then you will not have it on Dish right? Well my local CBS affiliate WKRG in Mobile has it, so why am I not receiving it on Dish?![]()
It was letterboxed and I stretched it out on my Hopper.Is your's letter boxed and stretched? This is the same station I referred to in an earlier post about the PQ being bad.
If you have 52 or 54 remote, Options button, 6 - Display Size, then set for whichever is full screen.I just checked 5.2 on my TV and it is not letter boxed, but it is 480i. The Dish version is 1080i. How did you stretch it with your Hopper. I have the Hopper 3.
It will affect every channel that is in the HD or SD category. So, If your channel is an HD channel every HD channel will change to whatever you changed it to. SD, the same way.Will this affect only that channel?
