Glorystar support please
mrswright
4
afton
Hello, I have had Glorystar FTA for a few years. I have had to replace a few receivers.
Today, because of lightening, I got a new receiver from them. Nothing is showing up on the screen after hookup. I also replaced the LNBF. The co axle cable going in the LNBF was hot. I took off the old one and put on a new LNBF and the connection warmed again. Thoughts? Not sure why this is not working out for me, I expected the Glorystar interface to come up on my screen and it did not.
I am not a geek but basically can hook up my own receivers. Thanks for your help.
M. Wright
M. Wright
I would suggest you remove the coax cable from the lnbf right at the dish. Then, hook a temporary length of coax up to the lnbf, and connect that directly to the new receiver. Even if you have to take the receiver & tv set right out to the dish, and use a long extension cord.
After a lightning strike, anything is possible. Even the coax could have "flashed-over" and is now effectively shorted. Or, if there's any switches, barrel connectors, or ground connectors inline, those could be shorted out.
Trying this as I stated above, eliminates all variables. If it now works fine, you need to find out if it's bad coax, or whatever. That can be done using an Ohmmeter.
Galaxy 19-27
signal quality never above 50%
