Universal LNB freq. settings
Chewie
352
199
California
Hello All
I have a question on how to set the correct frequencies when use User Defined on the satellite setup screen on Enigma Receivers.
I always get confused on it, I need to know which frequency should I input that will cover all the Ku satellites.
LoF/L
LoF/H
Threshold
On the Blind Scan Screen what frequencies should be enter for Start and Stop frequencies.
Any ideas would be appreciated.
Thanks in advance.
Regards.
Chewie
Reactions: c-spand
Hi Chewie. I was told originally that circular was for standard ku lnb with the V/H polarity. Then i saw it 10750 for all three L/H/threshold. Then it was L/10750 H/10750 Threshold/11700. So i too am a bit unsure what exactly to set it at. I am running Edison satdream NA. Maybe we can get this found out here.
LoF/L 9750
LoF/H 10600
Threshold/switch 11700
There is a built in 22khz switch in the LNB. When you select the Universal LO setting the 22khz will set to auto and you won't be able to use other 22khz switches in series with that LNB
You can start at 9750 and stop at 12200 if you like.
For a Standard LO 10750 LNBF on an Enigma2 image other than The North American Project, select LNB type: Circular.
That is all.
For The North American Project, select KU - 10750.
If you want to use the User Setting: Low: 10750, High: 10750, Switch Point:11700
OK, what if you are using a real circular LNBF...it has a LO of 11250
That is all.
Thank you so much titanium.
OS mio 4K
OS mio 4K Multiboot
