ALL the links are workingI'm sorry about the link. My phone is having problem today.
Amazon product ASIN B0748KYTZN
Sent from my SM-G965U1 using Tapatalk
I see all of them, so there must be something weird on your end.and yet I can't see any of them, even with ad blocker off
This morning 7/19/18 wgal scanned in 8.1, 8.2 and i get my local station wpsj on 8.1 - 8.4I have seen cases where two stations broadcasting on different RF channels displaying the same virtual channel were able to be distinguished by an ATSC tuner.
In the spirit of full disclosure you can read my signature below for a list of hardware I'm using. When it comes to TV antennas, bigger is better and a mast-mount pre-amp is a big plus. I recently rescanned and locked 73 channels off the antenna.
Yea, no one would take advantage of that.Also I noticed that 69.03 isnt officially listed as one of their subchannels. So the fact that they are still providing H&I on this subchannel may be temporary.
WFMZ-TV - Wikipedia
For the record, I don't like the way that Dish manages locals. A simple declaration that one isnt receivable from their house should enough for Dish to provide it. This package nonsense needs to end.
That's funny but seriously, if you are within a stations broadcast radius with a good antenna, that should be the only factor in deciding coverage. I guess I'm just a simpleton though.Yea, no one would take advantage of that.![]()
Don't forget terrain. That has a huge impact on reception. Also, define "good" antenna. Depending on where you are, a paperclip can work as an antenna. Or you need a $100 exterior mounted antenna on a rotator.That's funny but seriously, if you are within a stations broadcast radius with a good antenna, that should be the only factor in deciding coverage. I guess I'm just a simpleton though.
I knew the antenna was a variable when I typed it. How about using a coverage map? Here is one, but some bureaucrat made an official one somewhere. Why not just use those?Don't forget terrain. That has a huge impact on reception. Also, define "good" antenna. Depending on where you are, a paperclip can work as an antenna. Or you need a $100 exterior mounted antenna on a rotator.
These coverage maps aren't exact. Again, depending on terrain, you can be inside the coverage area, but not get a signal. Likewise, you could be outside the area with an excellent antenna (or high) and pick it up.I knew the antenna was a variable when I typed it. How about using a coverage map? Here is one, but some bureaucrat made an official one somewhere. Why not just use those?
WFMZ-TV Station Information | ALLENTOWN, PA
