C Band LNB recommendations on a Paraclypse dish
Richinald
35
7
Aruba
Hello,
Just wanted to request if there can be given recommendations about a good LNB that can withstand weather conditions.(rain, sun and corrosion)
Also a requirement would be that the LNB should have dual polarity (die electric plate) and can pull in weak and strong transponders on C and KU Band.
The LNB should be able to be installed on a Paraclypse "12 mesh dish, any recommendations would be appreciated.
Thanks !
Everybody would like to have that ;) Not much available for C/Ku reception unless you spend some money for a dual orthomode feed and 4 LNBs and it's still a compromise. Titanium carries a LNBF version that may work for you. I use a Bullseye II dual ortho.
Titanium Satellite - Store
Hello,
Thanks !
Paraclipse is a great dish, but the older ones don't work great on Ku band. Most people elect to use an offset dish for Ku. I don't do Ku, but if I did, I'd use a 48 inch dish. It is possible to motorize them, but as Magic said, you may want to give Titanium's a shot, it's a lot less expensive than purchasing a 48 inch offset dish. :)
Reactions: KE4EST
Hi take a look here,
Which combo feed LNB configurations or LNBF's works well or use 1 mtr dish for Ku?
The old paraclipse will work very well in KU band if time and effort is made on the installation, its one of only a few mesh dishes made with KU wavelength in mind,
Why most mesh dishes don't perform well in KU band is there wavelength is mainly for C band, this dish is a different kettle of fish,
If you want better results on the older dishes install finer mesh,
I'm not saying it will perform as good as a one piece solid spun dish of the same size but good results can be had.
Hi,
Thank you for all the feedback and recommendations,I appreciate it
It helps a lot for choosing the right LNB.
Richinald
Reactions: martin-f
One Bud 3 Receivers
Re-Install questions...
