We have an NFL thread in the Pit3 weeks in and no season thread? Bengals suck! Redskins looking good.
Yeah, I figured there would be one there now. LOLWe have an NFL thread in the Pit![]()
Steelers looked PATHETIC ...Bears beat the Steelers. LOL
Yes, the Lions got screwed ... (which happens often mind you)...Tough loss for the Lions yesterday, I get why they have that rule about clock run off, but when officials are reviewing a play to see if it was a TD. Oh well I am sure the rule will be modified just like they had the Calvin Johnson "process" catch rule![]()
After looking at all the replays, I still think he was in before being touched ...
Being touched before his knew is down doesn't count.
He does get touched AFTER hes crossed the line ...
Actually, the run off was NOT the correct call.Not sure if I disagree with your take completely. The call could have gone either way. BUT, after it was determined he was down, the run off was the correct call.
His KNEE was, but he has to be touched in order to be down.I know a lot of Lions fans are upset but I've seen the replays and still shots, he was down before breaking the goal line. The call was made correctly.
The Run Off is only for cases when a player is injured or a penalty happened on the play, which neither happened.
It all started when teams without a TO, had players fake an injury ... thats what the rule was put in for ... to prevent that from happening ... that did not happen here.No, that isn't what the rule says. It is basically set so it will not to allow a team with no timeouts an advantage. The play was reviewed and therefore the clock was stopped. If the play would have been called correctly on the field, there is little if any chance the Lions could have ran another play. That is what the rule was designed to do, not allow an unfair advantage in that scenario. It was applied correctly.
From SB Nation:
here is the NFL's rule 4.7.4:
If a replay review inside of one minute of either half results in the on-field ruling being reversed and the correct ruling would not have stopped the game clock, then the officials will run 10 seconds off the game clock before permitting the ball to be put in play on the ready-for-play signal.
NO Run Off should have happened.
Furthermore, he wasn't touched when his knee was down till after he crossed the line ... TD
NFL and officials screwed up.
Still not what the rule was put in place for.That is your opinion and no matter how the rule started, it now covers replay. The rule is QUITE CLEAR.
I wish they would learn thier own rule book.
What did you think about the call in the Pats vs Jets game yesterday?
It amazes me on how they missed that call. It makes no sense by the rules of the NFL.
