Press the "-" minus key on the front panel a few times and you will see return to main menu. Hit OK and then you are back to the main menu and no remote needed.I can see where I was going wrong, the unit only keeps the main menu up for a short period of time after booting up and the remote control needs to be used to bring back up the main menu
I believe 14 characters is the size.All sorted now with the menus, many thx for all the help.
I am in the process of creating a custom satellite list using one of the csv template lists from the Titaniuim web site. Would anyone know if the satellite name has a field size restriction for the number of characters and spaces it can contain for an upload to the ASC-1?
Thx
Correct you can ignore everything else, expect perhaps the back-light setting.![]()
Two ways I use. The counter starts at 0000 so I move the dish to where I want that to be and do a reset. But since I'm a hands on tinkerer, I have a bench motor with no limit system. I hook this to the ASC1 and program it, then move it to where my dish is pointed. Then hook it up to my system. When you have your positions set the ASC1 will remember where it is when you change your satellite list.
YESDoes the ASC-1 positioner count of 0000 start at the extreme West point and increase to +nnnn at the extreme East point?
YesAlso, can the positioner count go negative
