At your distance, I doubt you will see anything on VHF with the 4251.I wonder if the CM antenna has any ability to pull in VHF channels?
The antennas being so close is likely not helping either. If in your shoes, I would replace the RCA combo antenna with the lightweight/low windload VHF-Hi Antennacraft Y10-7-13 & mount it at least 1 foot above or below the 4251. This will really help improve the dynamic range of the 7777 which is likely suffering from some signal clipping due to the strong local FM's in the valley.
Thanks for the suggestion - - - question first. I wonder if the CM antenna has any ability to pull in VHF channels?
If so I could change the 7777 to combined and see if that makes any difference. No cost option and might be worth a try.
What do you think?
I just ordered the antenna you suggested. Only $38 plus shipping from SolidSignal. Many thanks for the good suggestion!! Most likely will not be able to install until next Saturday.
With my newly upgraded OTA setup - - -I just cancelled Dish to save about $48 dollars a month. :up
I now have OTA using a Tivo HD with Lifetime, FTA, NetFlix, Roku and computer streaming. The Tivo with Lifetime was the real key that allowed me to drop Dish. I still have a real DVR and my ROI is about 6 months of Dish payments.
I have not completely cut the cord but I'm much closer and the wife is very happy about saving extra money every month.![]()
Today I tested 3 different upgrades to my CM4251. Each time I recorded the signal levels for all UHF channels. Also, I must give credit to
http://www.digitalhome.ca/forum/showthread.php?t=96216&page=12
for most of the ideas used here. They had many good suggestions and the information was both technical and detailed.
If you follow that thread through to the end the members there modeled some other replacements for the bowties that may work better. The best one seemed to be a short Log Periodic antenna as it was easy to mount near the focus and still have great gain.
For your bowtie experiments I would try to shorten the gap between the small reflector and the bowties. Also replace that wood with plastic as it does reduce gain. The sheet metal can be replaced with tubing or heavy gauge wire bent to V shape. The elements could be lengthened to 8 or 9 inches depending on how low your UHF channels are.
Nice pix!! Glad to hear of your success!! Not sure how important channel 13 is to you??(good late night offerings & a few Ravens games not carried on 9) Unfortunately 13 is only beaming about 6000 watts in your direction. Their directional antenna limits power output to the west due to an interference agreement with channel 12 in Martinsburg. An FM trap from Radio Shack before the preamp may help if the internal trap isn't enough. Exactly how close are you to the WXBN transmitter?Anyway, I like this antenna a lot because it allowed me to get channels 7, 9 and 11 reliably but not 13.
Hope Antennacraft doesn't discontinue it. Winegard just discontinued the YA-1713, so now it's the only game in town.this AntennaCraft Y10-7-13 rocks!!!
