Ill probably be calling dish to upgrade from a 722 & 211 set up to a hopper and 2 joey set up. I dont want anyone drilling a bunch of holes in my house. I have coax and ethernet is every room in the house. Will that work for the install?
The node can be installed outside before entering the house and if you put Hopper where 211 and use the line for the 722 and the 2nd tv to cascade the two Joeys then no additional wiring should be needed as long and the line to the Hopper is rated to work with it.
It depends, is the wiring RG-6 rated at 3 ghz? you have to have that from the node to the hopper.The hopper will be going where the 722 is. The house is 4 years old, so im guessing the wiring is good
How many wifes do you have coming into the house. With a single Hopper, I think you only need 2. The installer may be able to use those.
If your wires coming in the house from sat go to the same central location that your coax to the house runs from I would put your node there. Connections from there should be easy assuming all are home runs from the central. You may have to upgrade some barrells to 3 Ghz.
I don't know about you, but I only have one wife coming into my house.![]()
The Joey and Hopper are not equal completely. The Hopper has PIP (I think) and Bluetooth so the location of the Hopper may be more strategic than you think.
So my house is wired with rg6 (single sheilded). No issues for dish, right?
You should be good. Joeys won't be an issue for sure, as they're able to run on pretty much any coax you could find. The Hoppers technically need 3 ghz rated rg6 between the node and hopper location. Your results may vary if you use existing cable that isn't rated at 3. If it's easy to replace that line, most techs will do so.
Who can i tell what the bandwidth is? Not all rg3 cables created equally?
Theres no way they can replace the line unless they rewire my whole house. The other option is to run a new line.
You mention that i would need the 3ghz between the node and the receiver, what about between the dish and the node? What is a node?
