11/14/2012 4:32pm - Uplink Activity Report - 119 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 11/14/2012 4:32pm - 119 changes
Uplink Comparison Range: 11/14/2012 04:16P - 11/14/2012 04:31P
Channel Additions:
5205(21) - KOZK [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Springfield, MO-PBS) (NA)
5156(8) - WDAZ [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 8 (Mkt:Fargo, ND-Devils Lake, ND-ABC) (NA)
5165(12) - KUON [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 20 (Mkt:Lincoln, NE-Lincoln, NE-PBS) (NA)
5165(12) - KUON [MPEG4 HD] added to Echostar12 61.5W TP 11 Spotbeam 15 (Mkt:Lincoln, NE-Lincoln, NE-PBS) (NA)
5185(17) - WNED [MPEG4 HD] added to Echostar12 61.5W TP 13 Spotbeam 4 (Mkt:Buffalo, NY-Buffalo, NY-PBS) (NA)
5174(33) - WITF [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (Mkt:Harrisburg, PA-Harrisburg, PA-PBS) (NA)
5174(36) - WSBE [MPEG4 HD] added to Echostar12 61.5W TP 11 Spotbeam 2 (Mkt:Providence, RI-Providence, RI-PBS) (NA)
5175(28) - WLWC [MPEG4 HD] added to Echostar12 61.5W TP 11 Spotbeam 2 (Mkt:Providence, RI-New Bedford, MA-CW) (NA)
5174(10) - WKNO [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 38 (Mkt:Memphis, TN-Memphis, TN-PBS) (NA)
5174(10) - WKNO [MPEG4 HD] added to Echostar12 61.5W TP 05 Spotbeam 7 (Mkt:Memphis, TN-Memphis, TN-PBS) (NA)
6391(52) - KFWD [MPEG4 HD] added to Ciel-2 129W TP 02 Spotbeam 41 (Mkt:Dallas, TX-Fort Worth, TX-N/A) (NA)
6391(52) - KFWD [MPEG4 HD] added to Echostar12 61.5W TP 01 Spotbeam 16 (Mkt:Dallas, TX-Fort Worth, TX-N/A) (NA)
626 - CNTSE [182] added to EchoStar14 119W TP 18 ConUS beam (NA)
626 - CNTSE [182] added to Nimiq5 72.7W TP 05 ConUS beam (NA)
690 - DUNYA [MPEG2 SD] added to Anik F3 118.7W TP 06 ConUS beam (NA)
716 - B4UMU [MPEG2 SD] added to Anik F3 118.7W TP 23 ConUS beam (B4U Music) (A) (FP)
718 - MTVH [MPEG2 SD] added to Anik F3 118.7W TP 08 ConUS beam (A) (FP)
817 - CD 12 [MPEG AUDIO] added to EchoStar14 119W TP 20 ConUS beam (Muzak - Ink'd) (A) (FP)
817 - CD 12 [MPEG AUDIO] added to Nimiq5 72.7W TP 25 ConUS beam (Muzak - Ink'd) (A) (FP)
5753 - INATV [MPEG2 SD] added to Anik F3 118.7W TP 13 ConUS beam (NA)
6851 - UP9 [MPEG4 HD] added to Nimiq5 72.7W TP 14 ConUS beam (Virtual Channel) (NA)
19243 - INATT [DATA] added to Anik F3 118.7W TP 13 ConUS beam (A) (H)
Channel Removals:
5766 - BVOD2 (A) (H) [134] removed from EchoStar9 121W TP 13 ConUS beam (Business Video on Demand)
6196 - WLNE (A) (H) [MPEG2 SD] removed from Echostar12 61.5W TP 11 Spotbeam 2 (New Bedford, MA)
6197 - WPRI (A) (H) [MPEG2 SD] removed from Echostar12 61.5W TP 11 Spotbeam 2 (Providence, RI)
6198 - WJAR (A) (H) [MPEG2 SD] removed from Echostar12 61.5W TP 11 Spotbeam 2 (Providence, RI)
6199 - WNAC (A) (H) [MPEG2 SD] removed from Echostar12 61.5W TP 11 Spotbeam 2 (Providence, RI)
9603 - DNBS (A) (H) [134] removed from EchoStar9 121W TP 13 ConUS beam (Dish Network Business Service)
Channel Moves:
6225 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
6226 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
6227 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
6228 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
6229 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
6235 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
6238 - DISH [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (Mkt:Abilene, TX) (NA)
102 - BLOCK [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (A)
153 - MLBSZ [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (A)
155 - NFLRZ [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (NFL RedZone) (A)
232 - RURAL [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
256 - PRAYR [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 21 ConUS beam (A) (FP)
349 - BLOCK [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (A)
362 - AXS [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (FP)
402 - USN [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
413 - PAC12 [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (A)
869 - UDEP [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
4100 - TENIS [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 32 ConUS beam (The Tennis Channel) (A) (H)
4119 - BIO [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 19 ConUS beam (The Biography Channel) (A) (H)
4501 - AXS [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
4601 - BIO [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 19 ConUS beam (The Biography Channel) (A) (H)
4632 - RURAL [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
4741 - NFLRZ [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (NFL RedZone) (A) (H)
4749 - MLBSZ [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 29 ConUS beam (A) (H)
4763 - TENIS [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 32 ConUS beam (The Tennis Channel) (A) (H)
4814 - UDEP [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
4815 - UDEP [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
5924 - BIO [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 19 ConUS beam (The Biography Channel) (NA)
6091 - SXM91 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6092 - SXM92 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6093 - SXM93 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6094 - SXM94 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6095 - SXM95 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6096 - SXM96 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6097 - SXM97 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6098 - SXM98 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
6099 - SXM99 [MPEG AUDIO] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
9442 - TENIS [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 32 ConUS beam (The Tennis Channel) (A)
9443 - BIO [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 19 ConUS beam (The Biography Channel) (A)
9591 - KABC [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
9591 - KABC [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 26 ConUS beam (Los Angeles, CA)(A) (H)
9592 - KCBS [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
9592 - KCBS [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 26 ConUS beam (Los Angeles, CA)(A) (H)
9593 - KNBC [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
9593 - KNBC [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 26 ConUS beam (Los Angeles, CA)(A) (H)
9594 - KTTV [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
9594 - KTTV [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 26 ConUS beam (Los Angeles, CA)(A) (H)
9607 - AXS [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
9643 - ROCKS [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (FP)
9795 - USN [MPEG4 SD] moved from Nimiq5 72.7W TP 14 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
30197 - IMAGE [DATA] moved from EchoStar11 110W TP 21 ConUS beam to EchoStar14 119W TP 19 ConUS beam (NA)
30198 - PTAT [DATA] moved from EchoStar11 110W TP 21 ConUS beam to EchoStar14 119W TP 19 ConUS beam (A) (H)
30199 - SCRUBS [DATA] moved from EchoStar11 110W TP 21 ConUS beam to EchoStar14 119W TP 19 ConUS beam (A) (H)
30202 - SXMAA [DATA] moved from EchoStar11 110W TP 21 ConUS beam to EchoStar14 119W TP 19 ConUS beam (A) (H)
Channel Package Flag Changes:
8868(17) - WWHB [MPEG2 SD] - EchoStar14 119W TP 04 Spotbeam B20 changed to Available (H) (Mkt:West Palm Beach, FL-Stuart, FL-N/A)
8868(17) - WWHB [MPEG4 SD] - Echostar12 61.5W TP 01 Spotbeam 9 changed to Available (H) (Mkt:West Palm Beach, FL-Stuart, FL-N/A)
9035(22) - KVMY2 [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 38 changed to Available (H) (Mkt:Las Vegas, NV-Las Vegas, NV-MY)
7817(12) - WSTE [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 49 changed to Available (H) (Mkt:San Juan, PR-Ponce, PR-N/A)
703 - ZCINE [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to free preview (A) (Zee Cinema)
704 - SETMX [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to free preview (A) (Sony Entertainment TV Max)
705 - B4U [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed to free preview (A) (Bollywood 4 U Movies)
709 - TIMES [MPEG2 SD] - Anik F3 118.7W TP 08 ConUS beam changed to free preview (A)
710 - HT [MPEG2 SD] - Anik F3 118.7W TP 20 ConUS beam changed to free preview (A) (Headlines Today from India)
715 - ZOOM [MPEG2 SD] - Anik F3 118.7W TP 08 ConUS beam changed to free preview (A)
717 - ZING [MPEG2 SD] - Anik F3 118.7W TP 12 ConUS beam changed to free preview (A)
723 - NDTV [MPEG2 SD] - Anik F3 118.7W TP 18 ConUS beam changed to free preview (A)
724 - NDTVG [MPEG2 SD] - Anik F3 118.7W TP 18 ConUS beam changed to free preview (A)
736 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam removed from free preview (A) (JUS Punjabi )
738 - GETPJ [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam removed from free preview (A)
929(75) - AUD07 [MPEG AUDIO] - EchoStar14 119W TP 20 ConUS beam changed to free preview (A) (Gumbo (Mono))
929(75) - AUD07 [MPEG AUDIO] - EchoStar15 61.5W TP 02 ConUS beam changed to free preview (A) (Gumbo (Mono))
946(76) - AUD19 [MPEG AUDIO] - EchoStar14 119W TP 18 ConUS beam changed to free preview (A) (Roadhouse (Mono))
946(76) - AUD19 [MPEG AUDIO] - Nimiq5 72.7W TP 25 ConUS beam changed to free preview (A) (Roadhouse (Mono))
950(77) - CD 1 [MPEG AUDIO] - EchoStar14 119W TP 08 ConUS beam changed to free preview (A) (Muzak - Screen Door)
950(77) - CD 1 [MPEG AUDIO] - Nimiq5 72.7W TP 25 ConUS beam changed to free preview (A) (Muzak - Screen Door)
951(78) - CD 2 [MPEG AUDIO] - EchoStar14 119W TP 08 ConUS beam changed to free preview (A) (Muzak - Rawhide)
951(78) - CD 2 [MPEG AUDIO] - Nimiq5 72.7W TP 25 ConUS beam changed to free preview (A) (Muzak - Rawhide)
961(79) - CD 12 [MPEG AUDIO] - EchoStar14 119W TP 20 ConUS beam changed to free preview (A) (Muzak - Ink'd)
961(79) - CD 12 [MPEG AUDIO] - Nimiq5 72.7W TP 25 ConUS beam changed to free preview (A) (Muzak - Ink'd)
963(80) - CD 14 [MPEG AUDIO] - EchoStar14 119W TP 08 ConUS beam changed to free preview (A) (Muzak - Concrete Beats)
963(80) - CD 14 [MPEG AUDIO] - Nimiq5 72.7W TP 25 ConUS beam changed to free preview (A) (Muzak - Concrete Beats)
4153(152) - MLBN [MPEG4 HD] - Ciel-2 129W TP 28 ConUS beam changed to Available (H)
4153(152) - MLBN [MPEG4 HD] - Nimiq5 72.7W TP 17 ConUS beam changed to Available (H)
6004(88) - SXM04 [MPEG AUDIO] - EchoStar14 119W TP 21 ConUS beam changed to free preview (A)
6004(88) - SXM04 [MPEG AUDIO] - Nimiq5 72.7W TP 15 ConUS beam changed to free preview (A)
6017(89) - SXM17 [MPEG AUDIO] - EchoStar14 119W TP 11 ConUS beam changed to free preview (A)
6017(89) - SXM17 [MPEG AUDIO] - Nimiq5 72.7W TP 05 ConUS beam changed to free preview (A)
9989 - TVJPN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam removed from free preview (A) (TV Japan SAP)
9991 - TVJPN [MPEG4 HD] - Anik F3 118.7W TP 32 ConUS beam removed from free preview (A) (TV Japan SAP)
Channel Renames:
8119(42) - WSAH (Mkt:New York, NY-Bridgeport, CT-RTN) - EchoStar10 110W TP 20 Spotbeam 04 renamed to WZME (Mkt:New York, NY) (A) (H)
8119(42) - WSAH (Mkt:New York, NY-Bridgeport, CT-RTN) - Echostar12 61.5W TP 15 Spotbeam 3 renamed to WZME (Mkt:New York, NY) (A) (H)
Channels in the system: 8738
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
Now what? ... If they're being dropped why bother moving them.
probably slates
Still nothing in the uplink this week for the PBS change that takes place in the Orlando market tonight. Station claims that dish would be ready. We all know how that is going to go. No PBS via dish in Orlando starting tommorrow.
might just be a fiber feed change..may not even require a uplink report
Not that simply, they will need to add an extra channel and change the calls on the other, as WBCC is taking back ch 68 as an APT affiliate and WUCF is moving from ch 68 to ch 24. Dish removed the uplink for WMFE 24 PBS a year ago since all they were transmitting until this week was VME as a placeholder.
And at 2:15 am that is exactly what dish foolishly did, they moved WUCF from 68 to 24, and mistakenly deleted channel 68 completely which is still on the air as WBCC 68, dish is so dish-connected from the customers and broadcasters it's just not even funny.
Somebody please assure me that Echo 16 is on track for Nov.20 - then I can finally, reliably get the Buffalo HD locals - including the newly added WNED (PBS). I hope the end is near for Rainbow 1 and its wonky spotbeams.
Satboyz
Tampa8 said:
RI - loses the networks in SD, gains PBS and CW in HD....
SD channels are still available, they are now 7770 - 7773. PBS and CW are up linked and not available. We can only hope they will be available someday.
5174(10) - WKNO [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 38 (Mkt:Memphis, TN-Memphis, TN-PBS)(NA)
5174(10) - WKNO [MPEG4 HD] added to Echostar12 61.5W TP 05 Spotbeam 7 (Mkt:Memphis, TN-Memphis, TN-PBS)(NA)
Why is the PBS station in Memphis not available in HD, it is uploaded but not available.
D
11/21/2012 4:32am - Uplink Activity Report - 4 changes
D
11/21/2012 1:02pm - Uplink Activity Report - 12 changes
