Do you want to pay for a standard ham 80M through 6M transceiver or a full blown Computer controlled DSP spectrum analyzer 160M through 0.125 CM four transmitter 8 receiver unit that weighs 450 pounds?
Basically: weight, size, current draw, cost, design time, reliability .......
QRZ FD K7EVI EWA Kli Co.
And who is on 0.125 CM? -- who is going to be using using 4:2:2 by the time the bugs get worked out --- and by the time the "Broadcast Standard" is worked out (or abandoned completely)?
Standard HF rig is 160M through 10M, although these days most have at least 6M and often have 2M and 70CM as well
By the way, where is there such a tranceiver that operates 1.8 MHz through 230 GHz?
By the way, I was on 13cm when AO-51 had a 13cm downlink but alas she operates no longer, along with probably the most famous 13cm downlink, AO-40. May they rest in peace!
While I appreciate your attempt at a ham analogy, it's apples to oranges. The difference between 4:2:0 and 4:2:2 is NOT in modulation at all. In fact, the signal can be received and recorded, just not played back on most set top boxes. It's the same frequencies, the same modulation types, just different data. It seems like all that would need to be done would be to decode those slightly different 1s and 0s into a 4:2:0 datastream. Like I said before, it has been done before with other types of encoding. When you take it over to a computer, the only thing different happening is you have software on your computer (a codec) that decodes that 4:2:2 signal. Why can't this be done in a box, regardless of chipset? The processor seems fast enough, there seems to be plenty of RAM. Is it a licensing issue with the codec? Too much of a programming effort?
A lot of pro HD recording equipment is 4:2:2 natively which I assume is why we see it with feeds. Is it worth the effort? That's not up to me to decide. It seems like no one seems to think so. Grander things have been done for the eye patch crew but the financial benefit to them for enabling that is great motivation. Having 4:2:2 in this box would give it another leg up on most any other box out there, but whose to say the Chinese won't take all that hard work, reverse engineer it and all STBs will have it? I'd just enjoy hearing from the technical end, someone in development what about the hardware can't make 4:2:2 happen with some software magic
GL in FD es 73
