This gives you the ability to download all the content from your 722 before you upgrade. You won't loose anything.
Which makes the upgrade much easier.
dwarren2 said:This gives you the ability to download all the content from your 722 before you upgrade. You won't loose anything.
Yes you will lose (not loose) something. You will lose ALL your timers.
Sent from my DROIDX
Take digital photos.
And transfer them to a laptop or tablet so you can easily read them at your Hopper location.
problem with that is it only shows the name, not the channel or new/all.
If you have a sling adapter. Log onto dishonline and then My DVR. Select times and then print out the list of timers. Then go into the timers on the dvr and write in the info on the print out.
I guess that also means it doesn't matter what type of hard drive to use, correct? Are there any size limitations or anything?
Because not every body on the forum is a tech junky.......
Im wondering when people will quit using ppl for people and spell it correctly......![]()
