My DSR-4200c receivers.
I had to buy 2 of the commercial receivers to get one to work. Price is low because the buyers do not know what they have and are lacking a remote control. The Remote control is needed to program receiver that costs $47.
These receivers are only good for 1 set of services at a time. I have my receiver on Music Choice. See avatar.
Both receiver said in the firmware 4200v but the Symbol rates were different on both. 3.75, 4.88 and 19.51. The other was 1.85, 2.44, 3.25, 4.88, 7.32, 9.76, 14.63, and 29.27. I can only assume that Motorola can load new firmware after the receiver is in the field and activated. Again both are marked 4200c. The sellers can not tell so buying a receiver is a crap shoot.
I purchased an exact remote at 800remote the only place that I could find.
Next step I clipped 2 of the 3 leads on photo transistor behind panel of 4DTV 920 receiver and cut traces on remote control leds making the 920 a UHF only as some of the IR remote keys interact between receivers. System works perfect now.
Using your DSR-4200V remote, enter the following commands:
1 Press Options -this will place you in the Options menu.
2 Press 3 (Customize Program Viewing).
3 Press 4 (Change Password).
4 Enter 9 9 6 with the remote and press the Time button to enter the Installation menu.
5 Move the cursor to the bottom of the screen and highlight "Factory Default"
6 Press the Time button on your remote. The receiver will reset to factory settings.
7 After receiver has reset to channel 100, repeat steps 1 – 4 above.
[FONT="]8 [/FONT]Press 2 (Setup ) - this will place you in the Setup Menu. Make the following entries by moving the cursor (yellow highlight) to the appropriate box and press
" Select":Verify the following: (selections designated by a red circle)Homing Disable = OFFVideo Format = NTSCLNB Selection = LNBPolarity = Does not matter unless you are using a polarity control device.Port = K/V or port receiving the vertical Ku signal or C band signal.
1 Press the Go Back button to return to the Installation menu.
2 Press 3 (Manual Tune) - this will place you in the Manual Tune menu.
[FONT="]3 [/FONT]Make the following entries by moving the cursor (yellow highlight) to the appropriate box and use the number or arrow keys to make selection:
operating frequency - 5150 = IF frequency. Example: 3895- 5150 = 1255
