Is there speculation motorola can remotely brick our 4dtv receivers? Is that possible to remotely make the box totally unuseable?
In theory they can do anything since they can control the maps and firmware. They could allow the 4d to only operate as a analog receiver with basic satellite tiles in it like when you do a MR. Since there will be no data stream to update the maps etc, we could be screwed.
What will happen? Most likely they will just abandon the thing like with VC-2. I'm almost certain they will send out a global deauthorization hit though.
Since we own our receivers, anything they do that destroys them would lead to lawsuits. Nobody has any right to mess with someone elses property. ...
Guys you seem to be overlooking one thing. The DC2 like the VC2 can hold two months of program keys. They could embed something in the second month spot that would be used for January starting in December. My subs run out the end of Sept that's it for my 4D I will start to go into protect mode then.
Isn't that for authorization? They publicize it happens on the last day of the month and is new for each month.
I'm thinking they would need to send new firmware down to change things drastically. If I see new target FW, I'll worry.
I thought channel mapping was in memory until it downloaded something more current?
I seem to remember the 10 year old satellites and generic tiles and old mailbox messages are present after a MR until current satellites are downloaded again.
They can in theory store the next months keys a month in advance. I never did a MR I can't remember if there were any generic satellites in my 4D when I got it new in 2006. I remember the channel count was way low like 500 though. Maybe someone who recently did a MR can shed some light on this.
The generics were written well after the 4dtv receivers came out.
A 4d receiver new out of the box still has the old "S2" satellite in there which was dead and gone even before the 4dtv even came out so you see how old the code is on a new 4dtv receiver. It only lists a few satellites and has no digital channels in it when it is new out of the box or after a master reset is done to the unit. Digital channels are added only after the unit is left to sit on the now Galaxy 18 at 123°W, I believe the receiver new out of the box or after a master reset lists it as G9 but after the new maps are sent it changes automatically to G0. Only after sitting on what is now "G-18" (G0) for you 4dtv'ers will the receiver pick up the new satellite/channel maps which include the generic maps.
Onto a few other things that some people may have forgotten or not know about....
Anyone remember back in 2002 when an attempt by Motorola to take away the ability to use the Generics for channels not mapped into 4DTV Models 905 - 920 - 921 – 922's?
Nicknamed "KILLER CODE 74" where the diagnostic screen "B" would show up as "MI" (missing information) instead of FP.
This code was first sent out in 2002 on the Star Choice satellites to test this on the 921's (with plans to use it on all the US models later on)
and anyone with a 920 or a 922 could pick up the code if they went to the Anik F1 satellite at that time and it rendered the receiver useless for picking up many "ITC" or "FP" digital signals. What's to stop Motorola from doing this again after December 31st?
(That code also stopped the Canadian 921 receivers from getting the guide information from the US which they could do up till that time for free.)
That code stopped being broadcast on F1 in August of 2002.
Or how about the code that Motorola put into the 922's for the "missing ratings information" that blocks out a channel that is FTA . If you have a 922 you only see the grayed out screen, which has been referred to in the past as the "gray screen of death". This particular code was not sent out to the 920 receivers.
only to the 922 receivers.
One may have to park the 4dtv on a satellite like Intelsat 9 (P9) before December and leave it there till the data stream is turned off to avoid any new killer codes if they fear that Motorola would do such a thing.
...Or how about the code that Motorola put into the 922's for the "missing ratings information" that blocks out a channel that is FTA . If you have a 922 you only see the grayed out screen, which has been referred to in the past as the "gray screen of death". This particular code was not sent out to the 920 receivers.
only to the 922 receivers. ...
This might explain why a neighbor could pick up more FTA channels on his 920
than I did on my 922! A few years ago I was trying to get him to upgrade to a
922 and he said, "Why should I when I get more channels ITC than you!!!"![]()
...... I have a genpix skywalker 1 and I can receive all of the fp channels without the maps. .....
