This is wat I used
Any specific instructions for using this file?
Can I load it through the USB?
Also, there was mention of a second file to load after this one. Did you use the latest Factory one? Or something different.
Thanks...
This is wat I used
Thanks...
Dish sued Sonicview a while back
http://www.satelliteguys.us/showthread.php?t=191213
so that might be why![]()
I am guessing that Sonicview wont be updating their Factory bins any time soon??
Have the Master box power "ON", and slave box power "OFF" completely.
Connect Master and Slave box with Null cable.
User remote control unit pointing at the Master and press YELLOW button and #4 (#1=Main software, #2=Channel list, #3 Bootloader, #4= ALL)
Now power up the Slave box by using the rear power switch and you should see it start transferring.
Wait until it finishes and reboots.
I was hoping you found a solution I purchased my box new now I only have 9 sat's to choose from but no one seems to have an answer. Thanks cigarman
OK.That already something. Thanks very much.I am going tu start some search on those files U just mention.ThanksAs far as I remember reading somewhere, try loading SysClean file 4.35, latest factory file 2.57, and latest TP & (empty) Channel List file for the sats you want to watch.
It mentioned to replace the C10 and C24 capacitors with radio shack part # 272-1032.
Ran to Ratshackatack and purchased 2 caps, took out the power supply board and removed and replaced the 2 capacitors as pictured:
total cost for fix, $3.49 since I already had the solder iron and some rosin core solder.
