America's Everything Pak value
Yeah, AEP is a good deal if you have one TV. In fact that could be applied to all Dish programming. $17 per extra receiver is over the top. I'm moving end of the month. Perfect time to switch, and I think I'm going to.
Well, one HDTV. My 722k is hooked to two normal televisions on TV2. So I can watch television in three rooms. The installer was stunned when I told him about my setup. He said he had never seen someone use RCA cables for TV2.
The fact I need only one receiver makes Dish Network a really obvious choice. If I got a second HDTV, that would change instantly... and that alone may keep me from getting the second HDTV.
As far as the bargain of AEP, it may be a better bargain for some than others. My bill would increase by more than $30 to get AEP, assuming I can get Platinum.
With all this said, I think Dish Network's new slogan should be "Your Mileage May Vary".
If you do get everything setup(MRV,SWM,DECA) on your original install.It seems if you want that later it will cost you more.;)
Or your TVs should vary,from what I have read if your want to keep TV2(SD) on a HDTV you need to keep your screen size under 40".;)
Best Viable Option--Replacing 722k for two DVR's?
Dish America gone as of today?
