OK, why do I want to upgrade?
Is there a handy site or thread someone can point me toward? I'm actually pretty happy with the current OS.
There are certain Dell machines that Mac OS runs fine on. Might want to do a google search for "Dell Hackintosh"Can I install this on my Dell Mini 9?![]()
There are certain Dell machines that Mac OS runs fine on. Might want to do a google search for "Dell Hackintosh"![]()
After the installation, I have found my first issue. My Macbook is only showing that it booted into 32 bit mode instead of 64 bit. I found a few things on the internet that I need to try to resolve this issue.
There is NO advantage to running a 64-bit operating system on the Mac unless you have more than 32GB of physical memory, because 32-bit Mac OS X doesn't have the limitations you'd assume a 32-bit OS has, specifically:
1) 32-bit Mac OS X is not limited to 4GB. If you're familiar with Intel's PAE (physical address extension), or even bank switching techniques going back 30 years to PDP-11s that could access 256kb of memory even though they were 16-bit machines, you know how this works. PAE enables 32-bit systems to use up to 64GB of memory. 32-bit Mac OS X supports PAE and allows use of up to 32GB of RAM (I've also heard "at least 32GB", so 32GB might not be the upper limit on a Mac).
2) 32-bit Mac OS X can run 64-bit applications
The only reason to run the 64-bit kernel is 1) you have more (a lot more) than 32GB of RAM, or 2) you're developing and testing 64-bit kexts.
There was no need to explain any of this as I already knew.
If I had intended the message only for you I would have sent a PM. That's great that you have the technical background to understand the issue, but you and I are in the tiny minority that understand it, and I bet there are others who actually learned something new from that post.
