inline amps
dumbjim
20
st. louis mo.
Anyone have a opinion on these little inline amps that are powered by your receiver? I have a cable run over 200ft, and was wondering if they help. I know you can't get something for nothing, meaning it might boost the signal but it also boost noise.
thanks
I have had them before, but honestly they usually create more noise on the line hurting your signal quality. If you are going long on your cable, use RG-11 coax. You will get much better results than using an amp.
Properly used amplifiers work fine. It is mostly about SNR and level.
Just to pick some out-of-the-blue numbers, let's say your receiver's equivalent noise floor is -70 dBm. Let's also say the background noise as received by the LNB comes out of the LNB at -50 dBm. And finally let's say the carrier you want to lock comes out of the LNB at -40 dBm. So very crudely you have a 10 dB SNR (-40 - (-50)). Because the LNB noise floor is much greater than the receiver's noise floor (-50 > -70), the receiver's noise floor will have negligible effect on the received signal quality.
Now let's run a long cable that attenuates by 10 dB at the frequency you are interested in receiving. At the receiver your carrier will now be at -50 dBm and the LNB noise floor will be at -60 dBm. Because the LNB noise floor is still significantly higher than the receiver's, you'll still get pretty much a 10 dB SNR and everything should work as before.
However let's run a longer cable that attenuates by 25 dB. Your carrier is now at -65 dBm and the LNB noise floor is effectively at -75 dBm. Because the receiver's noise floor is still at -70 dBm and now dominates, in simple terms your SNR has dropped to only 5 dB. That may no longer be enough to lock. Note to quibblers: in reality the SNR will be below 5 dB because the noise floors will combine, but the basic point remains.
Let's take the same longer cable and put a decent 15 dB amplifier right after the LNB. The carrier will be at -25 dBm at the amplifier output while the LNB background noise will be at -35 dBm. You still have a 10 dB SNR. But go to the end of the cable and attenuate these by 25 dB. This leaves a -50 dBm carrier and a -60 dBm LNB background noise. Because the LNB background noise is much higher than the receiver's background noise, you now have a 10 dB SNR thanks to the amplifier.
So why do people hate amplifiers? Mostly because they are misapplied or of poor quality. Too much amplification will cause the amplifier to saturate. Depending on its design, this can seriously degrade all signals passed through the cable. If the amplifier is noisy or significantly non-linear, it will be of no use at all.
Using RG-11 instead of RG-6 is safe. It will not saturate at the signal levels we use. RG-11 can run farther than RG-6 for the same attenuation. But, there's another factor many people ignore about amplifiers. Decent amplifiers are designed to compensate for the frequency rolloff in cables and that is usually for RG-6. In most cases I can get a flatter signal by running RG-6 with the correct amplifier than I could with the same length of RG-11. Also, decent amplifiers are cheap and may be less expensive than the incremental cost of RG-11 over RG-6.
There is another factor that might tilt the balance towards RG-11 on a long run: if your LNBs take a lot of power and/or you have a motor powered by the coax. RG-11 will have a lower voltage drop than RG-6. However when this is calculated, most of the time it doesn't matter. In these cases copper core RG-6 is preferable over steel core.
I've tried it both ways and much prefer amplifiers. In fact I generally use them for anything over about 100' because signals measure cleaner at the end of the cables on my bench spectrum analyzer. This translates to higher SQs on the receivers, too. Every time.
So what to do? RG-11 is safe. Amplifiers properly used can be better. If you use an amplifier, get a good name brand with a low noise factor and less gain than your calculated cable attenuation.
I did forget to mention if you use amps to get good ones with low noise ratings. The quieter they are the more they cost. I always try to run larger coax before using amps. It reduces you overall line maintenance by having less "active parts".
I have ran rg6 quad pretty ridiculouly far on a directv install and it worked. It was over 200 feet maybe 250'.
You don't need an amp for a 200 foot run all it's going to do is increase your noise level. I'm running between 175 and 250 feet on RG6 on two of my dishes with no problems. Just make sure that the RG6 you get is good brand and not the cheap stuff.
It is true you don't need an amp for a 200' run, but that doesn't mean you will have the best SNR, level and frequency response at the end of the cable. It may be that everything in your system has enough gain and sensitivity so it doesn't matter, but that is not universally true.
Properly applied, amplifiers have a completely negligible effect on the noise floor. In fact properly applied they can maintain the full SNR output by the LNB where a straight cable cannot. You may be confusing the noise floor as output by the LNB with thermal or receiver noise. An amplifier will raise the noise floor as output by the LNB by the same amount as it raises the signal. For practical purposes the SNR remains the same by doing this. You want to keep the LNB-output noise floor well above the thermal/receiver noise so the latter do not reduce your SNR. The AGC in the receiver will adjust the signal level to the optimum point for the front-end. If there is not enough level, the AGC can't do its job and you will lose margin.
I'm not trying to be argumentative. I can directly measure SNR deterioration of a long cable on my bench spectrum analyzer and when the correct amplifier is inserted, show the SNR deterioration to be non-existent. Correspondingly when I poll the Linux drivers of my computer-based USB and PCI receivers, I see exactly the same improvement.
The benefit of gain and frequency compensation for cable runs is well-understood in the telephone and cable worlds and without it we would greatly suffer. You don't have to do this for FTA, but if you have long cable runs and you don't, you likely will be throwing away some of your SNR.
I know in the few applications I have tried even the good blonder tongue amps, the noise floor went higher. I used a resistor once to lower the power to the amp and it helped restore some order.
Did the noise floor go higher or did the SNR/SQ go down? The actual level of the noise floor is ordinarily meaningless. Also were the BTs RF distro amps or something for OTA? I can't recall them making something like that for L-band in the recent past.
Properly applied, amplifiers have a completely negligible effect on the noise floor. .....
An amplifier will raise the noise floor as output by the LNB by the same amount as it raises the signal. For practical purposes the SNR remains the same by doing this. .....
I understand what you're saying here, however it seems to assume that the amplifier isn't introducing any noise of it's own into the signal. Plus it also seems to assume that the amplifier has a linear response, both across signal levels and across the 950-1450 band. Also missing from the discussion, is where do you put the amplifier, which I think is very important.
As you say in the middle quote above, the amplifier should affect the noise the same as the signal, provided that it has a linear response, however there will be noise added by the amplifier, and it seems to me that this will always lower the S/N. Of course this brings in the "completely negligible effect" phrase, and I think that it could be negligible if you have a high quality amplifier, and it is " Properly applied" as you say, however I don't really think that an off the shelf consumer amplifier plunked into the signal line at random can do anything but lower the S/N.
I don't have any knowledge about the design of these in-line amplifiers, but I'd have to guess that there is an optimum range of signal (including noise) level that it will amplify in a linear fashion, and that there will be some level at which some degree of clipping or attenuation will occur, and this non-linearity would seem likely to attenuate the signal more than the noise, although perhaps only on the stronger signals where it is less important.
But the linearity across the 950-1450 band is also an important issue. This can do some very strange things to the signal that the receiver ends up using. I'm not positive about the cause of the strange things I've seen, but I THINK that it must have something to do with the AGC you mention. Ie if the AGC is acting on the signal level in the whole 950-1450 band, but the amplification is greater say in the lower end of the band, then signal in the upper end of the band can actually go down to zero on noise and marginal signals.
On to the issue that wasn't mentioned, ie where do you put the amplifier? Since the LNBs already amplify the signal, and most likely are a higher quality than the amplifier in a consumer inline amplifier, I really have a hard time seeing any advantage to putting the amplifier out at the dish, and likewise, the AGC amplifier circuitry in the receivers is most likely higher quality than the inline amp, plus all the damage has been done by the time you get the signal to the receiver, so putting the amp near the receiver clearly is usually unlikely to help (I've seen a couple situations where it did help). Intuitively (I've really never felt the need to try an inline amp at this position), I think that the only place it makes sense would be mid-way between the dish and receiver. Ie a point where both signal and noise may have dropped down to levels where the amplification of the inline amp would bring the level back up to near where it was when it left the lnb, hopefully without introduction of much new noise.
But anyway, I think how useful the inline amp ends up being depends a lot on the quality of the amp. Since you've seen to have had success with them, I'm curious what brand amps you've used? I've been thinking of moving one of my dishes to a point where I'd be adding another 50' or so of coax, which will put me out past the 300' mark, which is where I think that an inline might become advantageous, however if I do this, I want to get a high quality amp, as I've observed that cheap amps have seemed to be next to useless.
So I'd be interested in recommendations for a good quality inline, and opinions on whether my mid run positioning opinion seems logical.
Also, slightly off topic, but a topic which influenced some of my comments above... I've noticed that the pass-thrus of receivers seem to have amplification, some better than others. I am curious whether this amplification is prior to the AFC of the receivers, or if it is part of the AFC? And does this amplification only affect the signal coming out of the passthru, or is it actually the first stage of amplification for the receiver itself? I've seen or read things that have suggested both sides of all both questions, so I'm curious.
Having a spectrum analyzer makes all the different in troubleshooting cable and other issues, BUT not everyone has one to use. Having access to one is a real advantage in troubleshooting and everyone's installation is most likely going to be different.
Of course amplifiers introduce noise, but so do receivers, LNBs and dishes. Even receivers have variable gain stages (AGC) and this does not come for free, either. The important part is to have the gain where it belongs. Lots of gain in a LNB is good. Modern LNBs typically have around 60 dB of gain and are very affordable. I haven't seen one post here where someone complained this was bad, too much, etc. But the moment when someone suggests adding an amplifier with say 15 dB of gain for some fraction of a LNB cost, alarm bells start ringing everywhere. I think there are misconceptions of what noise and noise floors are and how they relate to receiving the highest quality signal.
In the best case a dish will have sufficient signal gain and sufficient shielding of terrestrial noise and interference to deliver a decent signal to the LNB. Also in the best case the LNB will have a low noise factor, so it doesn't deteriorate the received SNR by a significant amount, and enough gain to ensure the SNR is maintained all the way to the receiver.
The receiver should also have a low equivalent input noise floor, but the design of receivers is always a compromise. Low noise detectors generally have a limited dynamic range over which they can operate, usually far less than the signal environment. So an AGC normally precedes the detector to better match the signal environment to the detector's limited dynamic range. If we stress the AGC with too much or too little signal, we will have suboptimal performance from the detector. Just as an aside, a wide dynamic range AGC is generally a tougher design problem than a fixed-gain amplifier.
Before proceeding, we first need to recall that noise combines non-coherently in a RMS process. If the noise floor input to the next component in the receiving chain happens to be the same as that component's equivalent noise floor, we will lose 3 dB of SNR. Ouch. What we really want is the input noise floor to be significantly higher than that component's noise floor. For example, if the input noise floor is 20 dB above the component's equivalent noise floor, noise combining will result in a 0.04 dB loss of SNR. That's a lot more tolerable. If there is a greater spread, the loss will be even less.
Whether the above component is an amplifier or a receiver, noise combining works pretty much the same way. If we ever allow the noise level output by the LNB to even approach the equivalent noise floor of any component in the signal chain, we're going to lose SNR. This includes any amplifiers, switches, splitters and the receiver. The gain of modern LNBs is roughly standardized to ensure that modern receivers have enough signal that the LNB's output noise floor is sufficiently above the receiver's noise floor. That way noise combining is negligible for a 'typical' cable run and switching system.
With longer cable runs, and often non-powered switches, the signal is attenuated along with the LNB's output noise floor. FTA systems pass the LNB output from 950-2150 MHz and often only 950-1450 MHz. The higher the frequency the more the attenuation. If the attenuated noise floor approaches the equivalent noise floor of the receiver we will start to lose serious amounts of SNR. If LNBs had higher gain, this would be less of a problem. But then we would risk overloading a receiver with shorter cable runs.
Let's look at a 36 MHz bandwidth transponder. The theoretical thermal noise floor for this bandwidth at room temperature is around -90 dBm. You can't do better than that. I haven't run calibrated measurements on my receivers, but they appear to have equivalent noise floors around -80 dBm. None of them want more than about -30 dBm of input level. My LNBs output a noise floor around -50 to -60 dBm in that bandwidth. That's about right because I am unlikely to see more SNR than would overload my receivers.
Let's take OP's concern about 200' of cable. For 100' of cable, RG-6 will attenuate 6 dB @ 950 MHz, 7 dB @ 1450 MHz and 9 dB @ 2150 MHz. RG-11 does better for the same length, but not incredibly: 4 dB at 950 MHz, 5 dB @ 1450 MHz and 6 dB @ 2150 MHz. At 1450 MHz that means I would lose 14 dB with RG-6 and 10 dB with RG-11. A LNB noise floor of -60 dBm would become -74 dBm with RG-6 and -70 dBm with RG-11. Without any amplifier I would lose about 1 dB of SNR with RG-6 and 0.8 dB with RG-11 because of noise combining in the receiver. Is RG-11 that much better?
But let's say I put in a 15 dB gain amplifier with the same equivalent noise floor as the receiver (-80 dBm). Decent amplifiers are better. I will lose 0.04 dB of SNR at the amplifier right off the bat. But the receiver will only degrade the SNR by 0.03 dB because the noise floor comes in much higher with the amp, and there is less noise combining. This is a total SNR degradation of 0.07 dB. That's a lot better than even RG-11 alone. How much is the difference? About the same as sawing off 1' from your 10' dish.
To answer your question about where to put the amplifier: as close to the LNB as possible. Good amplifiers can easily tolerate the hottest LNB you're likely to come across. They can't make up SNR that is already lost in a cable by putting them downstream. But if you were running an extremely long cable, spaced amplifiers might make sense.
In the bigger scheme of things -30 dBm is around 9 mV into 75 ohms. Even with the design objective of a low noise factor, there's plenty of supply voltage available to an amp (13 to 18V) where overload isn't a major consideration. I've come across a few terrible amplifiers that hit the circular file in a ns, but for the most part amps have proved very tolerant (and linear) of whatever I've thrown. Designing a good amp is a lot easier than most people think. Designing a good LNB is a lot tougher. Given the LNBs often used in FTA, I'm surprised there isn't more outrage about the marginally performing ones.
Precisely why a sloped (compensating) amplifier is normally a good thing. If the spectrum is flat coming out of the LNB, it will still be pretty flat at the end of a long cable with a sloped amplifier. That way the receiver will see the same level across the band and that will likely lead to more consistent performance. AGCs can be implemented in different ways. They don't have to act across the full LNB bandwidth.
I wouldn't assume the LNB amplifier and/or the receiver AGC is necessarily better in noise performance than in an inline amplifier. The amplifier is an extremely easy design with the integrated components available today. There is a lot more to designing a good LNB or receiver.
At the moment I like the Channel Master duals, partly because they're easy to mount and everything I have comes in pairs. I recently picked up some very inexpensive JVIs that appear to have the same specs, and put one on a dish last night. I haven't nit picked it, yet, but it looked about the same on the spectrum analyzer as the CMs.
The best place for an inline is at the LNB, unless you have an extremely long cable and the gain required is too much up front.
Depending on the receiver, the pass-through may or may not have a gain stage. I would be surprised if there was an AGC in the loop. Generally I'd generally prefer to have a little more gain elsewhere in the system and run through a splitter than take a pass-through off a receiver. But properly implemented it shouldn't be a problem. My Pansat 9200HD has two pass-throughs: the first is for the DVB tuner and that seems ok. The second from the DVB-S2 tuner (original card, not the new one) is terrible.
I have one and it mostly confirms what I suspect. That does save time in troubleshooting as you say. But I have an old HP bench unit that would be real pain to haul out to the dishes or on the roof. Instead I often use a Linux-based USB receiver that allows me to read very small differences in received SNR. That works well for most tuning purposes and cost me $85.
I had a final thought harking back to my days long ago as a chief engineer for several broadcast stations. If you've had problems with amplifiers applied to OTA television and radio antennas, please don't let this carry over to FTA satellite reception.
In FTA all the satellites we can receive are approximately the same distance away, they all have roughly the same output power in their TWTAs and their antenna gains are not too dramatically different. You're not likely to see more than a 10-20 dB variation from the strongest to the weakest. That makes it fairly easy to design a gain system because the risk of overload is fairly small given typical cable runs.
For OTA the problem can be huge. You may have a 1 MW station in the field across the street and you are trying to pick up a 50 kW station 70 miles away with a sizable cable run feeding half a dozen TVs in the house. The difference in received power is such that any mast amplifier is either going to overload, or swamp the distant station with noise.
This may sound like an extreme example, but every month I handled calls from people in fringe areas that had reception problems. In a few cases all that was needed was an amp and/or better engineering in the downlead (how I hated installers that would simply splice a bunch of 300 ohm ribbons together in lieu of a splitter). In the majority of cases, however, the problem was a misapplied amp.
Generally the issue was either far more gain than was required for the application, or the presence of a close-by FM or TV tower. People thought if they had problems receiving a weak station, all they had to do was get a 'bigger amplifier'. Sometimes pulling the amp out was all that was required. But most of these cases required either a lower gain amp, traps for the nearby transmitters or pads on the input to squeak the amp's gain into the right window. This was pretty easy for me, because I could calculate the received power for all the stations in the area and figure out what was needed. But this was next to impossible for the average Joe or Jane.
Distance between dishes??
Northern MN Birdview Find!!!! ALERT!!!!
