You don't know what spamming is, do you?
Well, we've already established that you are not shy about providing us with examples with your endless posts of nonsense.
I've sat and had the best and the brightest explain this to us, and I'm just stubborn. -- Charlie Ergen
Q (Chu) SIR, CAN YOU GIVE US A ROUGH NUMBER OF HOW MANY OPINIONS
THAT YOU'VE BEEN INVOLVED WITH OVER THE TIME OF YOUR CAREER?
A (Hillman) OH, YOU KNOW, SCORES AND SCORES. I'M NOT REAL GOOD AT
NUMBERS, BUT MANY OF THEM.
Enough with the quotes from whatever it is you are quoting; and can the caps too.
Have a civil discussion or refrain from posting in this thread.
AMEN!Enough with the quotes from whatever it is you are quoting; and can the caps too.
There is only one of us not having a civil discussion.
A FEDERAL COURT TRANSCRIPT IS CERTAINLY OFF TOPIC IN THIS THREAD.
Right, you don't know what "spamming" means. Nothing to be ashamed of.
Charlie is the best! I'm telling you! I can't believe how smart he is!!
He's the smartest CEO of the BEST company in the WORLD!!
Some people just want to be mods. It's best to ignore them.
Spamming sometimes refers to the spammer posting large body of biased text, often times repeating the same large body of text, the purpose is to scroll others off the screen. The spammer in such fashion has no interest in any meaningful analysis of the text he puts out, in this particular case he is not even capable of any meaningful analysis, his only goal is to repeat the same "large body of biased text" to move others off the screen.
Seriously, you don't see it? The irony is so obvious it's like it's hitting you over the head with a baseball bat.
You don't have much command of English to read and understand what is spam, so I will not blame you
I do want to make a point, your post appears a serious threat, I know you do not think it that way, but since your command of English is questionable I am just letting you be aware.
... The time sequence information for each segment is called a time stamp. These time stamps are monotonically increasing and start at zero each time the system boots up. This allows the invention to find any particular spot in any particular video segment. For example, if the system needs to read five seconds into an incoming contiguous video stream that is being cached, the system simply has to start reading forward into the stream and look for the appropriate time stamp. A binary search can be performed on a stored file to index into a stream. Each stream is stored as a sequence of fixed-size segments enabling fast binary searches because of the uniform time stamping. If the user wants to start in the middle of the program, the system performs a binary search of the stored segments until it finds the appropriate spot, obtaining the desired results with a minimal amount of information. If the signal were instead stored as an MPEG stream, [which is how the new E* design does now BTW,] it would be necessary to linearly parse [meaning "analyzing" time stamps or start codes] the stream from the beginning to find the desired location.
One of my favorite quotes from the hearing transcript.
Dr Storer is admitting that Dr. Barton testified that PID filtering is the physical data source described by the software claims:
Q DR. STORER, ON THAT LAST POINT, IS THE MEDIA SWITCH AN EXAMPLE OF THE PHYSICAL DATA SOURCE?
A ABSOLUTELY.
Q DO YOU RECALL MR. BARTON DESCRIBING THROUGH THE REST OF HIS DEPOSITION, WITHOUT HAVING TO SIT HERE AND READ INTO THE RECORD ALL OF THE FEW HUNDRED PAGES, DO YOU RECALL HIM DESCRIBING OTHER EMBODIMENTS OF THE PHYSICAL DATA SOURCE?
A ABSOLUTELY. AND HE, OF COURSE, WAS PROUD OF HIS INVENTION AND WAS DESCRIBING THE WHOLE THING, LOTS OF –- LOTS OF FOCUS ON THE MEDIA SWITCH IN CLAIM 1 AND THROUGHOUT THE DEPOSITION.
Q AND DO YOU RECALL HIM DESCRIBING AN ENCODER AS AN EMBODIMENT OF THE PHYSICAL DATA SOURCE IN CLAIMS 31 AND 61?
A YES.
Q AND DO YOU REMEMBER HIM DESCRIBING THE PID FILTER AS AN EMBODIMENT DISCLOSED IN THE PATENT FOR THE SOFTWARE CLAIMS 31 AND 61?
A YES.
Q THANK YOU, DOCTOR.
A ABSOLUTELY.
A YES.
A YES.
