Is there any reason to get a blu-ray plyer if my tv is only 1080i capable?Wife offered as a CHRISTmas gift but I didn't see the need with my tv.Am I wrong? What do you guys think? Moon.
Most TVs aren't 1080p and Blu-ray looks great on the ones that aren't 1080p. 1080i actually has the same amount of info as 1080p it just displays it differeently. 1080i is interlaced (it alternates 1/2 the lines very quickly), 1080p is progressive and displays all info on the screen at once. I belive that is correct and I'm sure someone will correct me if I'm not.Is there any reason to get a blu-ray plyer if my tv is only 1080i capable?Wife offered as a CHRISTmas gift but I didn't see the need with my tv.Am I wrong? What do you guys think? Moon.
Definitly get a Blu-ray player! (Especially if your wife suggests thatIs there any reason to get a blu-ray plyer if my tv is only 1080i capable?Wife offered as a CHRISTmas gift but I didn't see the need with my tv.Am I wrong? What do you guys think? Moon.
What size is your TV?
An upconvert might be a cheaper solution.
What kind of set is that? Are you sure you are using HD connection (e.g. HDMI cable)??? The difference on a 52" set from 12' away should be breathtaking!We have a 52" set and with our normal viewing distance of about 12 feet I can see a difference, but admittedly it is a minor one.
You can also look at it from this angle: If you get a Blu-ray player today (especially if you get a 2.0 model), you will be all set for many years to come.
If you buy an upconverting player today, then next year you will find yourself struggling with the same question again and will most likely end up buying Blu-ray then.
So, why waste money on an obsolete SD format form the last century? Go HD all the way!![]()
It is not a cheaper solution -- it is a joke. You can not upconvert a 480 picture and get more resolution out of it. You just exacerbate the problems inherent in a 480 picture.
If you have a HDTV, then you are only fooling yourself in beliving that an upconverting DVD player is anywhere close to the picture that a BluRay player will deliver with a movie in the BluRay format.
Moonpie, look at the new Panasonic DMP-BD35 or DMP-BD55. These are probably the best deals on a 2.0 player. If your AVR does not have HDMI input then go for the 55 - it has analog out. If your AVR does have HDMI then the 35 will do for less money. Check on the Amazon post in this forum and see if you can still get the deal on the 55. Good luck and enjoy.
I am thinking of getting the pan-35.I use optical out for my surround sound & use hdmi to the tv.This connection should work till I get the upgrade hdmi receiver shouldn't it?Thanks for all the help so far.Moon
