I received a message on my 722 a few days ago that said "You've been turbo charged!"
Anecdotally, the picture quality seems to be about the same, but I have noticed less macroblocking and picture breakup. Maybe there is a real improvement there.
The picture on CBS C has been great. The channel is doing a lot of SEC football re-runs, apparently from games originally done in CBS HD (at least the recent ones). This bodes well for SEC fans, since CBS just re-upped with the SEC for 15 years (football and basketball). I'll be able to watch some of those top games I missed in the past due to not being able to watch 2 games at once. The SEC now needs to get ABC/ESPN to sign on again.
But that's enough about the SEC, the best college football conference in the country...
Fitzie
Fitzie
Really? Every time I have turned it on there, even games from last year, have been stretched. They looked horrible. Even just a couple days ago they were being stretched. These were games that I watched last year in HD.
...The real test is how many people would have noticed/reported an improvement in HD PQ if Dish had not made such a big deal about "TurboCharging"?
Talon Dancer
Note that this "turbo-code" refers to error correction not improvements in PQ in the absence of errors. So the variable reports in this thread of PQ since "turbocharging" make sense if you assume that some subscribers' location/equipment setup (e.g. dish peaking etc) make them more susceptible to errors in the transmission thus requiring more and/or better error correction -- particularly the reports w.r.t. reduced motion artifacts. Hence for some the PQ may actually be better due to error correction while others see little or no difference.From the Broadcom website:
BCM4500
8PSK/TC Advanced Modulation Satellite Receiver
The BCM4500 is a single chip digital satellite receiver supporting QPSK, 8PSK and 16QAM modulations with iteratively (turbo) decoded error correction coding. It represents an industry milestone in terms of satellite system throughput and operating points. The BCM4500 also receives DVB, DIRECTV and Digichiper II (DCII) QPSK signals to support legacy system operation.
Features
- QPSK, 8PSK and 16 QAM Modulation with turbo code FEC
Isn't the operative word here ALLOW? Dish may use this extra bandwidth to ALLOW more "actual content" OR more channels per TP or both. And how Dish uses this extra bandwidth may change over time.The efficiency improvements in the error correction allows for more bandwidth to be used by the actual content. This allows a higher bit level or a higher resolution or both - hence improved PQ.
Bit rate is not the only thing to determine PQ, software improvement may help too. A $500 DVD player can display a much better picture than a $30 DVD player, even though they may use the same DVD disk.
Just because it costs more does not make it better. Poor analogy.![]()
