Trust me ! With this look angle ,You will have no Issues what so ever. D* HD look angles for my location are less then that any they were fine. 28 degrees or lees is when I would start to worry.Satellite Elevation
61.5° --> 37°
61.5° --> 37°
Hey, I have a 1000+ currently, The 1000.4 Quick Facts sheets says that is uses the same mast and foot as the 500+. Best I can tell, the 500+ and 1000+ use the same mast and foot, thus the 1000.4 uses the same mast and foot as the 1000+?
Also, I'm at Latitude: 30.3701° and Longitude: -97.9292°. I have a clear LOS to 61.5/72/77. Is my look angle at my location better with 61.5/72/77 or with 110/119/129? I'd like to decrease rain fade.
Scott - don't want to beat a dead horse BUT
I just got upgraded to an Eastern Arc setup... I have LOS issues with my 110/119 dish where as my 61.5 is clean. That and I was going back to DirecTV as I didn't want dual dishes anymore![]()
If they don't come with new cards what will I loose having an Eastern Arc dish now? I have AT250 and HD Pack Platnium I think?
My appoint is this coming Sunday here in the Hartford market.
Also do have the chart which shows what channel is feed from which bird? And lastly with the Eastern Arc setup I won't even benefit from the new Echstar 11 bird huh?
Thanks again
Thanks .:upAhh here is a good one that was just sent to me, it really explains what Eastern Arc is and how it all works.
This is a very good read.
Do you need to be in a ZIP CODE from the above mentioned cities in order to purchase the equipment for the Eastern Arc setup?
I currently have a Dish NOW!/YA! prepaid setup, so I actually don't have an account with Dish.
They do not have my name, address, Credit Card, SS#, etc...
The only thing they would even have on file is the Receiver # for the prepaid card/greenmoney pak use for uploading prepaid programming.
So, if this is the case, I would be considered a "New" customer since, theoretically, I do not exist
I want as little to do with them as possible.
I am quite handy at setting up/installing my own Dish.
But do I have to live in one of the above areas(zip code placement for locals) in order to buy the equipment I want?
I want to:
1. Buy a New ViP222 w/new smartcard for a 2-room installation(1 HDTV and 1 SDTV)
2. Buy the New Dish 1000.4 for the Eastern ARC reception. No LOS issues for me
3. Install it myself. Again, I am quite handy, and after downloading and reading the instructions, does not look that difficult.
4. Order 1 of the Standalone TURBO HD packages only. NO LOCALS. I get my locals(actually about 10 HD locals I could not get signing up with Dish for locals)using an outdoor antenna. Most likely the Turbo HD Silver at the minimum.
5. NO CONTRACTS WITH DISH. I will own the equipment and stop and start as I see fit.
Can all this be allowed with the new Eastern ARC.
Can one buy the neccesary equipment from a local satellite dealer, and do the install/setup themselves without any interference?(this is my most pressing issue).
Thanx in advance.
Eastern Arc is not available yet, so you were not installed with Eastern Arc.
Sorry...
either you do low signal strength, or no line of site, 5 degrees of clearance or more. unless you live in an area that gets really heavy rains, if the installer installed it right you shouldnt get that much loss when it rains.my 110/119 gets some really bad rain fade and wind fade as a tree near the slot blows in the way :-( so i'm either going back to CableVision or DirecTV
also, i just noticed the last part.
cut down the tree, problem half solved
I didn't know you can prepay. How do you sighn up for that and does directv do that too.
I have the HD Absolute package with Brazilian channels for my wife. I currently get the Brazilian channels from 61.5, but according to that PDF internationals will be coming from 118.7 in the future. Will I need some type of equipment change to keep getting the Brazilian channels?
Reason I'm asking is because I live in Indianapolis, but have "moved" to Atlanta to get the big four networks in HD. Is Dish going to be trying to send a technician out to my service address to change my dish for the internationals?
