I wouldSo, in the meantime, I was wondering if maybe I should try to turn my Satellite to 119 to get Nasa and hopefully Angel One.
no need for a sat fuinder. Use the receiver to do the finding. As noted above, most receivers you can put your zip code in, select dish 300 and the dish and it will tell you the elevation and azimuth for the dish. The elevation will most likely be different (higher or lower depending on your location)Could someone help me? I have a compass that I have been using to try and get some digital channels that antenna Web says I could get, so is it the same idea, turn the dish using the compass as direction, or will I need a satellite signal finder that I have read about in the forums.
Thanks in advance for the help. This forum has been great! I wish I had found it before Sky Angel made their decision.
Katybug
we're here to help
