Once I had signal locked from my Slimline, I did use a meter to fine tune. It made a little difference but not much. I have signals from high 80's to high 90's. and even a couple of 100's on all 5 sats.
Have any of you guys had any luck installing the slimeline ka/ku band dish without the help of a signal meter? I am planning on installing it later this week, and was wondering if the 20 dollar meters from ebay are any good, or just to pay an installer the 80 bucks to do it. Any thoughts?? Thanks
I have heard of people aligning them without any meter, using the signal strength on 99 or 103 (which only works if you are near enough to a spotbeam, of course) after an initial alignment on 101 (and 119 for tilt).
I did mine that way as well, didn't want to spend the money for a meter that I would use 2-3 times a year.
Everything in the 90's for the101,110,119, 99 and 103 in the 60's but I don't know how accurate the meter is for the new sats at this time.
Jimbo
I use a meter..Nail it every time..it's easy.....I did mine that way as well, didn't want to spend the money for a meter that I would use 2-3 times a year.
Jimbo
I too installed my slimline with just the receiver.
I found 101 and got it aroudn 95+. Checked 119 an it was about the same, mid 90s on most transponders (had set tilt before placing it on the mount).
Then I switched to 103c and found most in the 70-80s. I peaked that for a few minutes, got them in the mid 90s, then locked it down. Re-checked 101/119 and still 90+. Then checked the spotbeams on 103s & 99, and the beams that I can pickup here were mostly 98-100. I know of 3 HD LiL markets that I get beams for here, and all looked good.
Not too hard if you know what you are doing and start with 101 then peak to 103c.
Spend the time making the mast plumb & secure
Joe
Thank you Masterdeals,
People see to think this is rocket science, perticularlly those that are installers, they had to learn somehow, how did they do thier first installs.
Not everyone can afford to have a 4 hundred dollar meter sitting around the house collecting dust for the half a dozen times I would need it a year.
Jimbo
Good work Joe,
I hope this was the first thing you did !!!
Jimbo
Speaking of mast: what size pole does the 5lnb slimline au9 take?
I have a 1 5/8" currently for my outbound Dish Network 1000.2...Glad to see I can aligng it though without a meter, they have my install booked out for over a month...I cannot wait that long!
