I have a motor problem, fellas, and I need some engineering help.
One of my setups WILL NOT track the arc. I can zero it on my TS satellite (G-11), run it to AMC6 eastward and I have ZERO quality. Run it to G10R westward...NO quality. I have to adjust the elevation to get it to come in. What works on the west side elevation-wise won't work in the middle of the arc, and what works on the east end wont work on the center or west.
Obviously I checked the plumb of the pole, I am alright there....I am with in 3/32 or so all the way around, no better or worse than my other setup that does fine.
The difference in the two setups is the motor itself. The one I am having problems with is the new style with the thinner brackets and u-bolts. The u-bolts are clearly bent from tightening them to the pole so they are tight. So I put a torpedo level on the bracket itself, and the results startled me. The bracket is clearly not plumb to the pole! See pics below.
