Correct.IT t is not the same information twice but the making of a complete picture.
And this is the picture you get. Are you happy with it?
Diogen.
Does HDVD do AVCHD?
To get a piece of mind - Yes....wouldn't it be better to have one of the more expensive units that output 1080p?
In theory - Yes.In most if not all cases shouldn't progressive source material work better to a digital display than interlaced?
AVC (or H.264) is one of the codecs used to encode movies in both formats, HD and BD.Does HDVD do AVCHD? Again thanks for your patience.![]()
I don't know.If I record an AVCHD program on a Sony or Panasonic camcorder, burn it to a minus-R disc will it play on a HDVD?
Just looked for a few minutes through the latest Home Theater magazine. They review a few 120Hz LCD panels, including XBR4.So is Gregg saying the XBR4/5 don't do 5:5 for 24p? They are essentially doing 3:2 pulldown and doubling?
In a small insert the reviewer claims to hate interpolated frames the Samsung and Sony do the most.
And drops a rhetoric question: Where is 5:5? I guess the Sony XBR4 doesn't have it...
Diogen.
Motionflow adds either one interpolated frame for1080p/60 sources or four interpolated frames for 1080p/24 sources to each source frame to reach the 120Hz refresh rate required by the set's 120Hz operation. If you turn the Motion Enhancer off, each source frame is simply repeated as many times as needed to get to 120Hz, with no interpolation.
As I said, it wasn't in the review of the set itself.The online review does not say that: Home Theater: Sony Bravia KDL-46XBR4 LCD Digital Color TV.
Sony's processing performed much better, however, when converting 1080i sources to the set's 1080p resolution. It still did not recognize and deal with 3/2 pulldown, but it did perform the deinterlacing properly and only rarely showed video processing artifacts with a 1080i or 720p source.
BTW, this is not exactly encouraging
Diogen.
I agree, it makes 24p input very important. The less processing the better. Having the player take 24p, change it to 1080i or 1080p then having to have to TV set detect the 24p and reverse the whole process is just asking for trouble.
