If you are having trouble...
First let me say I was checking with both tuners, all evening since I got home and all worked as stated above except for 9300. However in the last 10 minutes it has started working also. Looks to be NFL channel.
Opposite for me... everything had been working fine, including 9300, until recently, now I'm getting 721 error.
If it is NFL, I should have it (Plus HD package).
480 -- works
481 -- works
498 -- Grey Screen
9300 -- Channel NOT purchased
9301 -- works (Discovery HD)
480 & 481 - work
498 - blank (although it's been fine previous to this)
9300 - showing NFL Net working but not HD and I've got the NHL logo in the bottom right and a Directv Logo with TX1026 in the top left. Also, audio out of sync
9301 - works. Discovery HD
Hardware:HR20-700
Software: 0x18a
Channel 498: Searching for signal on Satellite 771
Channel 480: Searching for signal on Satellite 771
Channel 481: 103 B-Band Even BBC confirmed working (gray screen)
Channel 9300: Searching for signal on Satellite 771
Channel 9301: Works...Info Commercials (was DiscoveryHD earlier)
And what does all this mean???
480 -- works
481 -- works
498 -- Black Screen
480 --- working
481 --- working
498 --- working
9300 --- Worked for NGC and A&E then 721 with the NFL Network. After adding sports pack to my services channel is working again.
9301 --- working
What do you mean "adding sports pack to your services"
Adding the DirecTV premium service Sports Pack to my existing base package (Total Choice Plus).
09/25/2007 xxxxxxxx HBO, STARZ!, SHOWTIME, & CINEMAX - Disconnect Adj $-5.60 $0.00
09/25/2007 xxxxxxxx Sports HD - Charge $0.00 $0.00
09/25/2007 xxxxxxxx HBO, STARZ, CINEMAX, & SPORTS - Charge $5.60 $0.00
I have Total Choice Premier with HD and DVR service which includes the sports pack. I am not getting the NFL Network on 9300. :mad:
Do you have this listed in your account recent activity?
I think 9301 is the only one working for me now. Im tired of this.
Do you have premier or sports package? What they are showing appears to be NHL network. There's a big NHL logo in the bottom right corner of the screen. However, they are using content from the NFL Network since NHL Network doesn't exist yet. I'd suspect that the NHL Network will be a sports package channel so unless you subscribe to it you won't get it on the test channel. Maybe D* is testing channels from the various packages to make sure that they billing/authorization system is working correctly.
I'm getting both 9300 and 9301 and I haven't had any problems with no matter they've shown on 9300. However, I have the premier package so I should get whatever they put on the test channels.
Sunday Night NFL HD
K-CAL Lakers game time delay and NBA League Pass
