Titan TV Broke
Lone Gunman
3,207
868
southeast
Didn't know exactly where to put this so if it's in the wrong secton, please move it to it's proper place.
I've been using TitanTV to keep up with programming schedules for a long time but here recently it has starting horking up every time I open it and it does that on ALL the computers I have here in the house?
So, does anyone know if there is something else out there that is similar to TitanTV that I could switch over to?
Thanks....................
I was just on today and their site worked fine here. Sometimes when they make even a small change to a site it will mess things up unless you clear all your stored cookies for it. I had that happen with Amazon recently. I couldn't get the page to display correctly until I cleared all cookies for them and signed back in. After that it worked fine. Maybe clear them for Titan and see if that helps. :)
IF you have an ad-blocker, especially uBlock origin, disable it and Titan will work again, though you'll be inundated with ads.
It started doing that for me also the other day. I've had it happen before with an ad change, and put in a bug report on uBlock's Github. They fixed it quickly. I haven't done that as of yet, but it couldn't hurt.
Ok, I just submitted a new BUG REPORT. Same issue as last May when I first submitted one. That was caused by hardcoded German ads.
They must have done something on their end because I had to log back in otherwise it's all good and working like it's supposed to.
I stay logged in,so that skips one hurdle.
Click your link to the site,choose your time from the drop down list,spinny wheel will start but you can scroll up and down your channels.If you want a different time or list,click the link again and make your choice.You just have to keep going back and forth.Don't use the <>,it's a PITA but you can get what you're looking for,until whoever fixes whatever.
My TitanTV was working fine until recently were it looks like it isn't completing an auto update. Doing F5 on the browser gets the update done OK. Don't know what changed to cause this issue.
The issue with TitanTv and uBlock Origin is now fixed, per comments on my bug fix. You would need to go into the uBlock Settings, click on "Purge all Caches", then "Update Now" buttons, let it finish updating, and then TitanTv should work fine for you again.
Reactions: FTA4PA and waylew
I wasn't using ublock so I must have some other issue.
Is it still acting up for you. and did it start very recently? If so, it might be due to the same issue, meaning some new ad or something that doesn't like ad blockers. For what it's worth, I also have Malwarebytes installed, and IF I leave the "Ads/Trackers" switch ON, it also did the same thing in making TitanTv clock after hitting the forward button a single time. I normally leave that switch OFF for all sites, as I have no need for two different ad blockers, and uBlock is better.
I just wish TitanTv had a paid subscription or something, where you could pay a few bucks to turn OFF all the ads. Because they have more ads than any other website I've ever seen. Without an ad blocker, it's absolutely worthless in even trying to use it.
Reactions: Hyper Casey
FYI, Adblocker Ultimate is on both Windows and Linux Mint (multiboot) computers running Firefox browsers and ALL my systems DUMP COOKIES and History when I close out my browsers.
If I turn off Adblocker everything with TitanTV works OK except I get all that ad crap!!
Just saying..................
Dump it and switch to uBlock Origin, as you now know that's working. Or figure out how to submit a bug report to Adblocker Ultimate
Now I'm getting hassled with a popup wanting me to turn off my ad blocker. Are there any other sources for programming listing?
Johnny, I've been looking around for ANTI-block blocker detectors, and found a few, except I haven't as yet figured out how to make them work. IF you figure out a way for TitanTV, please let me know. I'm using Firefox as a browser
You CAN stop it by using "Script Blocker Ultimate" and disabling Javascript, except that then you can't jump to new timelines from the first page. So, it IS a javascript issue, and just needs a way to just detect their javascript code they are pushing and let the results go through without causing the "Please disable" message from coming up.
I am with primestar31 - "I just wish TitanTv had a paid subscription or something, where you could pay a few bucks to turn OFF all the ads. Because they have more ads than any other website I've ever seen. Without an ad blocker, it's absolutely worthless in even trying to use it."
I find it works pretty well on my android phone, but on a PC you may as well forget it now. I am not going to disable my adblocker.
Reactions: primestar31
Yesterday it started working fine again. No nag to turn off my ad blocker, no ads, and does everything as normal. Either something automatically changed on my uBlock Origin, OR TitanTV turned off the nag for now.
When I have to start paying subscriptions for everything is when I start curtailing my activities. I thought about donating and subscribing for everything i use but I'm just not that rich.
Precision C band lnb
Cband has become more frustrating....
