This is a review of Satellite AV’s newly designed mast clamp for the GeoSatpro 90cm Offset dish. This is a good quality dish and that is what influenced my original purchase.
Earlier this year I purchased my first Ku band dish from Satellite AV. I chose a GeoSatpro 90cm Offset Dish. Dish arrived on time and in perfect condition. In addition, and big plus it contained all the bolts needed to assemble and the instructions were understandable. The install went smoothly.
In September I was reading the forums at Satelliteguys and seen that Satellite AV had redesigned the mast clamp for the GeoSatpro 90cm. This new mast clamp had three bolt holes on it as compared to two holes on the original. I thought back to my first install and remembered that I had to tighten the original very tight in order for it not to move. Therefore, I thought that was an awesome added feature.
Not only that, it had six raised bumps (grips) inside the mast clamp that would grab the mast pole I thought that would definitely keep the dish from moving. In addition, ribs along the outside of the mast clamp gave it a sturdy feel. The original had a smooth inside and outside and looked a bit plain.
The only problem I had the old model and I wanted the new and improved mast clamp. I contacted Satellite AV and inquired about purchasing the new clamp. The new mast clamp looks good on my setup. As I expected the new clamp held to the HH motor mast tightly. I did not have to over tighten it. The new and improved designed mast clamp on the GeoSatpro 90cm gives it a better reason to buy it.
