For the final years the alternate was only on 209-1. They still labeled it "ESPN Alternate", but it was only used for the weekends where ESPN2 and ABC swapped games in portions of the country.
directv is not likey to have that live 24/7 they will likey have it as an part time channelI don't have 100% confirmation yet, but RedZone is probably going to be on channel 211.
Does Anybody have Red Zone as a Full time channel ?directv is not likey to have that live 24/7 they will likey have it as an part time channel
I don't think it has ever been Full time.
Thats not having programming 24/7, all that is is a Slide to show they have it ... I would not consider that having it 24/7Actually typically the NFL's contracts require providers to carry it 24/7, even during the offseason. During the offseason it typically just shows this (from my Spectrum TiVo). Whether they will make an exception for DirecTV or not remains to be seen, but it likely would set a precedent they'd have to honor then with other providers too if they let them make it part time.
Thank you, that is the point I was trying to make. It might not have true "programming" on it, but I would expect the channel to be active all the time like it is on other providers as you describe.That slide is coming from the NFL's Red Zone channel, it's not inserted by the provider and is the same one that the feed being tested by DIRECTV stream is showing. It's also not a still image, the background gridiron moves around while various music from the NFL library loops in the background.
It doesn't matter what's on it, they are still devoting a QAM feed 24/7/365 to pass along whatever NFL Red Zone is sending out via Galaxy 13 TPN 22. The local Blue Ridge system here does the same thing where Red Zone's video and audio streams are always taking up 15 Mbps on RF 59, Program 2 (14.5 MPEG-2 1080i video, 384 kbps primary AC-3 5.1 audio, 192 kbps secondary AC-3 stereo audio). If it were a part time feed, they would only have the QAM feed active during Sunday afternoons or share the bandwidth with other part time channels like what some cable companies do with their RSN alternates. i.e. Optimum's NYC DMA systems have MSG2, MSGSN2 and YES2 share a dedicate sports alternate channel, and if they need all 3 RSN alternates live, they pre-empt the scrolling guide channels.
DIRECTV's part time channels are truely part time. Whenever they are not in use, they are remapped to Ku and Ka offline slates and their bandwidth is repurposed for CINEHD and in some cases SD Infomercial channels.
Never thought a cable co would still use MPEG-2 compression! Comcast here uses MPEG-4The local Blue Ridge system here does the same thing where Red Zone's video and audio streams are always taking up 15 Mbps on RF 59, Program 2 (14.5 MPEG-2 1080i video, 384 kbps primary AC-3 5.1 audio, 192 kbps secondary AC-3 stereo audio).
They can use SDV to make it not use bandwidth all the time.Actually typically the NFL's contracts require providers to carry it 24/7, even during the offseason. During the offseason it typically just shows this (from my Spectrum TiVo). Whether they will make an exception for DirecTV or not remains to be seen, but it likely would set a precedent they'd have to honor then with other providers too if they let them make it part time.
Don't all new channels go through this process on their respective channel number?For DIRECTV Satellite, Red Zone is now in test mode on channel 211 as a Ka Offline channel, so it looks like it will only be carried part time for satellite customers.
Not all of them, some go in test already mapped to their TPN-PID slot.Don't all new channels go through this process on their respective channel number?
Thanks for the reminder of that awful tease. One last year to go of not being able to watch so many Pac-12 football and basketball games without paying for a second TV service for DIRECTV customers.Every other national addition in the past 3 years like Marquee, SportsNet LA, Newsmax HD, TVG HD, SoYummy, BNC/Grio, Cleo TV, Showtime FamilyZone, Pinoy Box Office, OPM TV, AMC+, SariSari, OWN West, Hogar de HGTV, Barvana, Atrescine, Nuestra Vision, Estrella News, Meganoticias, Bounce, Grit, Cozi, getTV, LifeS, EarthX, Daystar HD, Daystar Espanol, EWTN Espanol, FMC and MeTV were mapped to unique TID-PIDs when they first appeared in test mode. Even channels that ended up never going live like Pac12 were mapped to unique TID-PIDs
