Hello,
I would like to inquire if there might be a member that has experience setting up/ calibrate a Paraclipse Classic 12 PT satellite dish, the dish is mounted to the pole, as well there is a new LNB installed,
The problem is the two large "silver" bolts were replaced, since the original ones were extremely rusted and one of them was bended, so there are new bolts installed, the problem remains how to align those two large silver bolts so the satellite dish can track the C and KU Band correctly, since this was a procedure that I never did.
A satellite technician friend that is helping out, is also trying to find out how to do this procedure.
The request would be to describe/walk through in a simple term: the procedure for setting up the large silver bolts for the dish - if correct would be the elevation level - (according to the Paraclipse manual a inclinometer would be required) so the dish can track the arc correctly.
I have attached several pictures for reference, more pictures can be provided upon request.
According to the Paraclipse manual found on the internet this procedure on the two silver bolts would be for adjusting the elevation, but feel free to correct the information mentioned is wrong.
Latitude, Longitude and location data for setting up the dish is on the island of Aruba in the Caribbean Area.
Thank you all for your help and guidance, it is very appreciated.
