Join the SatelliteGuys Folding@Home Team!
:clapping:clapping:clappingKudos to Foxbat for passing the 3,000,000,000 point barrier. Well folded, but not stapled spindled or mutilated :hatsoff2 .
Thanks! Poor Voyager6 is stuck in the 2,000,000,000's; all alone, in the dark... (Sorry, I crossed Sci-Fi universes there...)
Alas, every once in awhile, I wonder what it would be like if all those Points were Doge... But, thank you, I'l take the Points Shout Out!!!
It is.
Two things...
The new machine I was given with the 1080 card in it... well I just updated it to Windows 11. Kind of surprised Windows 11 installed and was running in about 4 minutes. It seems faster, lets see if it helps F@H.
Second my old machine had a bad work unit and was stuck on it for a few days. I got it fixed and that machine is processing again. :)
Let’s hope there are fewer problems with Windows 11 Folding than there were using Windows 10 (cough)(Updates)(cough)…
I have something similar going on with a project to crack a .zip file password that I've lost. The project never finishes because there is always a Windows update that reboots the machine before it finishes. The tool that I'm using doesn't appear to have a resume feature (this was my bad for not doing my due diligence).
So far so good on Windows 11... but there is not much new to windows 11. As I said it took only 4 minutes to install over windows 10, which tells me a few patches were applied and poof you have Windows 11.
As I've said, it barely qualifies as a point upgrade but the new, somewhat arbritrary requirements force it to be marketed as a big change.
I see where Microsoft is revamping the qualification tool. What a mess.
On my older machine I had to uninstall Folding@home and reinstall it again. It would run good for a day then the 1070 card would fail. Also installed the latest Nvidia drivers as well.
I should be doing about 2.2 million a day with both machines.
Reactions: Foxbat and KE4EST
Disappearance - 103 W AMC1/Spaceway 1/DirecTV 10/DirecTV 12
Software Update Coming
