SDR C/Ku Sniffing?
the typical L-Band frequencies, so usually 950 to 2050 MHZ. I'm not sure what the upper limit of the Airspy R2 is. My RTL-SDR cuts at about 1700 MHZ
If you want to check the beacons, many are published here: http://frequencyplansatellites.altervista.org/Beacon-Telemetry_Americas.html and here: http://frequencyplansatellites.altervista.org/Beacon-Telemetry_Atlantic.html
you then have to convert to L-Band. by subtracting the LO frequency (or from the LO frequency if C-Band)
so for example a beacon at 3950 MHz would be seen by the SDR as 5150-3950 = 1200 MHz
Note that it's not uncommon that the beacons be on circular polarization on an otherwise linearly polarized satellite, or vice versa
you should also be able to see narrow transponders on the spectrum in SDR#
Looking at the manual for my Chaparral CR-10 c/ku band receiver that I mainly use as a dish mover for my FTA receiver, I notice that it has separate outputs for Base Band and Data. The BaseBand output has settings for Deemphasized, Emphasized, Unclamped and Clamped. There is also a terrestrial interference filter that can be switched in. Would using Baseband or Data output to an SDR receiver give better results than using the Loop Out on the FTA receiver?
no I don't think that would work. The baseband on an analog receiver was the result of the first FM demodulation of the analog signal, in which you would have found the color subcarrier at 3.58 or 4.43 MHz and the the audio subcarriers at 6.20 and 6.80 for most US signals and often 6.65 or 6.50 for European signals. Now with digital stuff, I would just expect the baseband to be an unusable mess
There are a lot of very narrow bandwidth C-Band frequencies on 95.0W (Galaxy 3C). Has anyone took a look at this satellite in the C-Band range with some type of SDR device?
I had to closely monitor everything on G3C from the day it went live at my last job. There is a special 10MHz wide Ku transponder that shuffled data and telephone calls between a US site and several Latin America sites. You could see it all with an SDR but would need an appropriate modem to demodulate things and proper equipment to see the date or hear the phone calls. I believe this has been abandoned in the last several years and the traffic has moved to another satellite.
Otherwise I can't think of anything that can be received and actually heard off G3C with an SDR.
Bummer, Universal Radio is Closing
Can you send MSSTV on C4FM mode?
