So today I finished up the mediocre job my installer did last weekend. I ran the 3 additional coax lines from my AT9 and grounded it too. I took out my old 4x8 multiswitch and put in the WB68. I connected my H20 to it to make sure everything was hooked up correctly. Checked my signal strengths on the H20 and I got everything from 101 and 99 ok, but 110 and 119 were odd. With sat 119 I would get no signal on the odd transponders but a good signal on the even ones. With sat 110 I wouldn't get a signal on any of the transponders. I checked all connections, hooked up the H20 directly to my AT9 to make sure it wasn't a problem with the dish; everything was working perfectly when straight into the AT9. After 15 minutes of messing with this I thought it might be a receiver issue, so I hooked up one of my older RCA receivers to the 2nd port of the WB68. I checked the RCA, and I was getting signal on all transponders. Ran upstairs to the H20 and all of the sudden I was getting good signal to all the transponders I should be.
Does the WB68 require at least 2 receivers to be connected to get enough power? It's the only explanation I can come up with for the situation I encountered. I know that no one would ever probably hook only 1 receiver up to the WB68, but it's probably good to know for people installing these things.
