Guys,
I know that there are many alignmet help threads around but couldnt find one with a similar issue as mine.
I have been a long time dish user and i will be switching to directv soon. Im trying to get my dish aligned but after spending one day i couldnt
My setup
Receiver: R16-300. I bought this years ago and never connected it, it is still brand new and has a SWM port on the back where im connecting the LNB cable
Dish: Slimline
LNB: SL3-SWM
Alignment gear
Rough alignment to get sat signal was done with an ASL1 and old analog meter. Fine tuning of the signal level done with the IRD signal level monitor
The problem
I installed the dish and roughly aligned it according to the el, az and tilt for my zip code, after finding signal on 101 and aligning everything im only getting readings on the higher transponders. My levels are
1-8:0
9-16:0
17-21:0
22:99
23:90
24:0
25:0
26-28:100
29:0
30-32:100
No matter what i do i cannot get signal on the lower transponders. I read a thread saying that sometimes you can get this behavior if you are pointing to the wrong sat but i find it hard to beleive that im not aiming at 101 now.
This morning i even took the receiver and TV out to test connected directly to the lnb bypassing all the house wires but the result is the same.
At this point im thinking that i may have a bad receiver or lnb. I have a SL5 laying around somewhere in my basement and will try to find it and see if anything changes, however if you have any input on what could i be doing wrong, it would be much appreciated
thks
My setup
Dish: Slimline
LNB: SL3-SWM
Alignment gear
The problem
1-8:0
9-16:0
17-21:0
22:99
23:90
24:0
25:0
26-28:100
29:0
30-32:100
thks
