What firmware have you found works the best in the X2? The only one listed here is the one from April 9th and I know there has been several others released since then.
April 20th works the best of all of them (IMO)
Not able to find that April 20th firmware on legit? is there another place that you know of that has it?
I downloaded the 4/9/13 firmware off here earlier today as it's suppose to have the USA sat map.
They probably won't ship it until Monday so it will be likely be the end of next week before I get it. Meanwhile I'm trying to get all the "stuff" in order to start using it.
Hit OK, then use FAV to move to sat to sat. There is also a SAT boton
Carlos, on the X2, after hitting OK, in the channel list, pressing either the FAV or the SAT button does the same thing, that is, they just go to another sat, there is no list, so I have no way of knowing what sat is going to come next when I hit the Button.
But, I just noticed, on the Geosat HDVR1200, pressing 'SAT' button in channel list will bring up a list of Sats to choose from, FAV button does nothing.(I have not set any favorites)
Do you have any satellites selected and scanned in? If you don't, how can they be brought up in a list?...
As for April 20th firmware, I screwed up my previous posting and now fixed it. I meant MAY 20th. Not sure where it vanished to, but I'll see if I can upload it here. Carlos is right though, you might want to test several firmwares and see what works best for you. The more I hear about the quirks of the SatAv HDVR1200, the more it appears to be almost EXACTLY the same as the X2.
Ok, file is in the moderation queue. You'll have to wait for Ice or one of the other mods to approve it.
Yes, I have sats selected and scanned. Does your question mean that the sat list works for you? If so, please tell me which firmware, and which key presses, makes it work, thanks.
And, I think they are exactly the same... I'll have to take the covers off both and compare. The remotes are identical in size, shape, and keys layout, BUT, there are different functions and labels for a few keys. Geosat doesn't have the "click" like X2.
I'm wondering if the firmwares from one will work on the other??? <One of these days I may learn to just leave things alone....NAH, won't happen...LOL!>
Which is better overall useage and advantage for the X2 HD Premium, the HDMI connection or the Ethernet connection.
Also Pros and Cons for both connections.
You could ONLY hook up to HDMI and watch stuff on the receiver without access to internet stuff, but if you only hook up Ethernet, you'd be staring at a blank screen on your tv set, lol.
