Heartbreaking frustration!
Yes, the 500GB hdd was formatted on the dvr. A couple of times. I haven't tried the thumb drive yet; I may later. Trying to find one of the listed compatable hdd's, but the thumb drive will be a nice testbed.
I had four opportunities to record a program I really wanted, the two-hour Fountainview Academy Christmas program. First time, on the dvr external HDD, "Wrong File" on playback attempt. Second attempt, using the output from the dvr to a stand-alone dvd recorder (dvdr) with a full hdd, trying to record to a dvd-ram disc, nothing. Third attempt, make room on the dvdr hdd and try again. The s-video cable connection was loose, and all I got was the audio. Ok, one more chance. Reinsert and check the cables, and ---heartbreaker, all I got was two hours of Glorystar channel 1.
Either the dvr-1100c has a timeout after which it goes to the Glorystar Channel, like the old Chapparal used to return to its home satellite after 6 hours, I think it was, unless that was disabled, or, I suspect more likely, the automatic update came into play.
The manual is not overly informative on some of these matters.
Question 1: What is the I-4 Channel Lock? Why should I use it, or why should I not use it?
Question 2: If the V-2 OTA automatic update feature is turned off for a period of time and later turned on, will it "catch up" all the bypassed updates?
Question 3: If a timer recording happens to overlap a return to Glorystar channel 1, which is given priority? (I am thinking here of setting the timer on the dvr as well as the dvdr to "firewall" the channel so that the dvr is on the correct channel as it feeds the dvdr at recording time. Should work, if the timer is given priority.)
Edit: Just read on another post about the automatic update on Monday night; my dvdr timer recording was Tuesday 6:00am PST!
Thank you, and Healthy and Happy 2010.
Richard
