This is the problem I am having and what I am doing about it. When I do a blind scan with my view sat it will only search transponders that are in the sat file. The old and the newest sat file is missing alot of trasponders. This makes me miss alot of channels. For instance I have never saw a PBS yet. Sometimes I would scan a sat for channels that I know are there and miss them. They would not even show up. But then I would do another scan and it would pull them in. When I am talking about a channel list I am refering to the channel list in the box that you get from doing a blind scan. What I did to try to remedy the problem was when I would do a scan that would get say "channel X", I would back up my channel list with my jump drive and delete the list. Then rescan and see if it would pick it up again. If it did not get "channel X" on the next scan I would load the back up of the channel list back into the box and it would work, "channel X" was viewable. So that got me thunkin. I loaded my backup list into channel master and manually entered in the transponders,I found a channel I was NEVER able to scan in and manually entered the freg and symbol etc and the channel name. Next I loaded the modified list back into the box and bam like magic the channel was there. So now I going through lyng sat entering in ALL of the tp settings for ALL of the channels including the feeds! I have only been messing with channel master for 3-4 days now but I think I have the hang of it. I have been so busy entering in information that I have not had time to test my progress. I suspect that I will be finished with the channel list by the weekend.
I know there are rules for not discussing things that may or may not be up there, but I found that the transponders that were in my "channel list" were giving me problems picking somethings up. I'm sure most of us here know of a few things that in the clear right now and if someone else has a problem like I am having they will never get to see some channels. I was also ending up with alot of duplicates even after doing a factory default and turning the lnb power off on all other sats except the ones I was scanning. I hope that this method will end the channel problems that I am having. I would like to share this list after completion as long as it does not conflict with the rules. I was thiking of not including the scrambled channels but then I read somewhere here that sometimes, somethings are open and sometimes there not, I think there was an espn news that just did that. My goal is to have a universal channel list for ku band that is nice and clean, without all of the clutter and sats that your don't have a prayer of getting a signal on. Also I am not doing c band as I may not get the dish I scored up until spring. I was hoping that we could share this list and with everyone working on it by adding to it we could have a nice up to date list. One very good benifit is that if all of the feed channels are listed and already loaded a person would not have to waste time doing a blind scan to see if anything is lit up, just flip through the channels.
I'm not sure if I am going off the deep end or not but I would like to know if this is a good idea.
