Hello everyone!
I am trying to install WorldTV service (or to be specific Setanta Sports is all I care about). I am a complete newbie when it comes to satellite.
Today I received the install kit.
Arion AF-2500 receiver with software 2.5.20.18
75 cm elliptical (?) dish (nor a round one) with single LNB
The satellite is in front of my house mounted on my porch fence, single coax line goes from the LNB to the LNB in on the receiver.
I know approx area in which to point the dish but the satellite is Galaxy 19 and the only one I can pick from the list is Galaxy 25. I assume this is the old satellite that is no longer in service? I also read the settings for Galaxy 19 should be the same?
The problem is I get no signal at all. None. Do I have to change some settings in the receiver? I just find it odd that with 4 hours spent moving the dish around I was not once able to get any signal.
The settings are (default settings, did not change a thing)
DISEQC SETUP - 2 input switch
Tuning status
Frequency 12152000
Symbol rate 20000000
LO(KHZ) 10750000
Polarization - Vertical
Signal level goes from 84 to 90%
Signal quality is always at 0%
I have no idea which transponder to select (the one selected is 11789MHz 28125KS Vertical). I am located in Urbandale, IA, zip code 50322 if that helps. Thanks for your help.
Tuning status
Frequency 12152000
LO(KHZ) 10750000
