Hi.. in my experience (both in house and RV) ALWAYS use RG-6 with satellite. It's a little harder to work with but WELL worth the trouble and cost.Thanks for the reply. I have a spare bedroom that Comcast could not get cable to so I have to run a split off of the bedroom TV to this room which obviously isn't to nice to look at. Can they improve this situation when they hook me up? Also, I believe I was told to purchase RG-59 for use when I use a Dish in my RV. is that incorrect?
He is dead wrong. Get another installer.When I asked my installer the same question about using my cable tv cables, stating that I wanted new RG6 cable (old cables were about 10 yrs old) he told me the Zinwell 6x8 switch would make all my old cables RG6.:haha:yikes:shocked
For the cost of the cable, it simply is not worth reusing existing cable. It is so easy 99% of the time to simply barrel a 59 to 6, and simply pull it through. A two story fish replacement can be done in minutes. Rarely are this internal cables clamped. Easy to check, a person on eqach enad, pulling, is there felt tension? Even if there are a few clamps, often the cable in will just pop the cable from the clamp.Pretty much. Looking at the specs of the 5LNB dish and RG59, I wouldn't attempt to use any more than 25-30 feet of 59.
I know this for sure Comcast techs may not enter an attic.Thanks for the reply. I have a spare bedroom that Comcast could not get cable to so I have to run a split off of the bedroom TV to this room which obviously isn't to nice to look at. Can they improve this situation when they hook me up? Also, I believe I was told to purchase RG-59 for use when I use a Dish in my RV. is that incorrect?
Yes this will work. But only if the existing pre wire had not been stapled by the original install company. I can tell you this. It is code that all wiring installed in an electrical rough in must be stapled. That includes tel wire and coax.For the cost of the cable, it simply is not worth reusing existing cable. It is so easy 99% of the time to simply barrel a 59 to 6, and simply pull it through. A two story fish replacement can be done in minutes. Rarely are this internal cables clamped. Easy to check, a person on eqach enad, pulling, is there felt tension? Even if there are a few clamps, often the cable in will just pop the cable from the clamp.
One hint, it helps, after you barrel the two cables together to wrap the cabel and barrel with tape to make it a smooth shape, plus it adds strength to the connection.
Some remove the connectors, strip the outter, shield and center insulation away. Twist the center condutors together, then securely tape. Makes the resulting joint even smaller if there is doubt about getting 'hung'.
