I've read Sadoun's page on grounding as well as the page over at DBS Install regarding proper grounding.
As I understand it, both the coax and the pole itself needs to be grounded. No problem there.
Right now I'm trying to figure out how to run my satellite ribbon cable into the house. If i run the whole ribbon into the house right up to the receiver, the coax for sure isn't grounded properly unless I cut it before it enters the house and add a ground block (grounded via a #10 wire back to the demarc box's ground, and less than 20' long) outside. I don't have a problem doing this but I was thinking about it and thought it might be better to run the coax to the demark box as I would with a normal dish and just split off the actuator / polarotor wiring as it passes the TV outside and pass it through the wall directly. The coax would run down to the demark box and come back to the TV via the exisisting E* dual RG6 run that I'm currently using for my SG2100 / Ku dish and my OTA antenna. The OTA I can Diplex on one of the lines if needed and realisticly I could diplex my single run to the SG2100/Ku dish on the existing house wiring if it came down to it.
Which way is correct? Are both correct? If one way is wrong, why?
I appreciate any input. I drew up a quick drawing to show what I'm trying to do. the two different pairs of blue line represent the two different ways to run the coax into the house.
It isn't in the drawing but i plan on replacing my SG2100/Ku dish's RG6 run with a dual RG6 with messenger ground run to ground the pole.
I noticed in the positioner bundle of wire that there is a base wire mixed in that I don't have a use for. There is what looks to be a ground lug on the motor right where the cable strain relief is. Is this yet another ground? If so, where does this ground connect on the other end of the run?
Thanks in advance!
Thanks in advance!
