Winegard RV Satellite dish question
MisterJim
8
NE Ohio
I just purchased a used motorhome with a crankup Winegard satellite dish on the roof. The previous owner used it with a DirectTV receiver. Can I use my Dish VIP211 receiver with this antenna? Am I correct in assuming the antenna will receive either Dish or DirecTV depending on the proper receiver and aimed at the proper satellite. I believe I should try to aim it at the 119 satellite. I live in NE Ohio. Thanks for your help and I apologize for not being very savvy with all this technology!!
You should be able to point the dish at any 1 sat at a time you want, depending on the control unit for it. Depending what channel you want to watch, you may have to move the dish
The 211 can pick up and use the signal from any sat on the western arc (119/110/129) or the eastern arc (77/72/61.5) If you want HD channels try 129 or 72.7
Thanks very much TimberWolf; I will try to line it up with a satellite later today and I think I will use DishPointer.Com to help me get it pointed correctly!
Sling adapter/ reciever reset
Dish Remote Access iPhone App Problem
