Does anyone have this information for the Winegard 76cm (31") ? I found a thread that had the focal point distance to center of mounting bolts and to the top and bottom edge of the dish, but it was for the 1m dish. Ether my arm is really bent (dosn't look it) or I'm missreading the specs.
Information I have is:
Effective Aperture 76 cm / 31 "
Antenna Height 87 cm / 34.3 "
Antenna Width 80 cm / 31.5 "
Antenna Weight 4.18 Kg. / 9.8 lbs.
F/D .59
Offset Angle 24 degrees
Focal Distance 44.6 cm / 17.56 "
There are 2 adjustment option, the holder moves in/out at an angle so it also moves up/down. And the LNB of corse can be moved a little. I am using this with a Invacom CP/LP and sg2100. My first try I had both all the way in and got from about 79w to 123w, but it was marginal and I have clear view. I am at 110.89, 32.23 and from what Im told I sould be able to get more.
I had a problem with the motor clamp crushing the pipe partly because the streght section after the bend was too short I replaced the pipe with a section of fence post cut and welded with 2 joints at about 22 degrees to get the 45 the original had which puts the weight over the roof mount. I spent a good 30 minutes with 2 angle finders making sure the new post was vertical. After mounting the motor I set the shaft as close to 62 degrees (32 plus the 30 bend in the shaft) as I could get it again using both angle finders as there is a very slight difference between them.
I was told by someone on another board that it should be 17.5 from the bottom edge of the dish to the front of the LNB which is possible setting everything back. But with that setting I could only get to about 93w LP after setting to 110w CP and that was marginal. Decided to try going the otherway from 110 and seemed to eb able to fine tune the az on 116.8. Was late and thought I had it, so went down, reconnected to my VDR (used a Neusat 6000 on the roof for alignments), and found all I could lock was 116.8 and 110. If the motor elevation is suposed to be 32 degrees then arc curve should be right. So Im assuning its the dish focal point. I read here and am now told by others that its to the center of the dish bolts. The range I have to center is 19.5" - 20.75". That's a bit far from the 17.56" listed to just be a bent arm.
F/D .59
