Will This Work - Modifying Shaw Direct Set Up
Frenchophile
322
MI
Hey,
So I have two 30" dishes, one pointed at each Satellite, and from the LNBs, I have two 2x1 switches. works good for my 505 and 319. With the new 630 coming out, hoping that it works great, I will want to switch out the 319, but I need another line coming into the house. Will the 5x8 Eagle Aspen work with this set-up? Thanks
Hook up the outputs from your F1R aimed dish to the 13V inputs, F2 to 18V
that wont work as the LNB's are unstacked
you need to hook the F1 lines to 13v & 18v and the F2 lines to 13v+22K and 18v+22K
Anole has a real good explanation in the FTA area but here is how it looks (its a FTA setup but the recievers can be Directv or Shaw since they all use 22k switching)
attachment.php
Brain fart - mine is hooked up exactly the way you show in your diagram Iceberg.
Thanks for correcting my error.
update:
got everything hooked up according to the picture (thnx ice!). one receiver (505) is working perfectly, the other (319) is not getting any signal from either satellite. will do some further investigation tomorrow and provide further updates.
update: it works
update:
label line 1 as the one going to 505 (worked yesterday)
Label line 2 as the one going to the 319 (didn't work)
so first, I checked line 1 in all the other seven ports of the switch to confirm it works correctly.
then i checked the 319 with line 1 to confirm the receiver works correctly.
Then I went to the basement, where the lines from the switch connect with the lines in the house.
Then I checked line 1 in with line 2 out - works
Then I checked Line 2 in with line 1 out - does NOT work
I checked the integrity of connectors (compression), and they seemed to be grossly intact
So then I replaced line 2 in from the switch to the basement and everything works. (yay!)
the interesting thing is, line 2 had been giving me problems from day 1 of setting everything up 2 yrs ago, and I thought I fixed the problem with new connectors, but I guess there was something in the line.
anyhoo, thanks again for your help and humoring me. Next on the agenda will be a 630.
Shaw Direct in TN
NO CFL Games on NFL Network in Canada - Why?
