The AM21 works perfectly fine with the HR54.
I get that now with the HR44. I reposition the antenna and the message clears.Curious if you ever lose the signal from your AM21 to HR54? It happens with regularity to me — switching to an OTA channel, I often get a black screen with an error message regarding signal loss. I have to disconnect the AM21’s USB connection, wait a few seconds, then plug it back in. After a few seconds, the station pops up.
No. I do have one channel that periodically won't tune in without changing channels back and forth a couple of times but that is an issue with the channel not the AM21.Curious if you ever lose the signal from your AM21 to HR54? It happens with regularity to me — switching to an OTA channel, I often get a black screen with an error message regarding signal loss. I have to disconnect the AM21’s USB connection, wait a few seconds, then plug it back in. After a few seconds, the station pops up.
Where are you located?Interesting. I can’t reposition my antenna as it is about 30 feet in the air. Shouldn’t be any signal problems here — I’m 15 miles line-of-sight from the local transmitters. TiVo OTA box on the same antenna is not showing any issues. Will mess around with this more the next time it happens.
Have you tried replacing the USB cable ?Curious if you ever lose the signal from your AM21 to HR54? It happens with regularity to me — switching to an OTA channel, I often get a black screen with an error message regarding signal loss. I have to disconnect the AM21’s USB connection, wait a few seconds, then plug it back in. After a few seconds, the station pops up.
I wish they would come out with a new model. Could really use a USB dongle.
