I know this is all speculation since Charlie does what the heck he wants, but will Dish go full resolution on the HD signals when the new bird goes up?
Is Direct running at full resolution now?
Only on the new MPEG4 channels, the old MPEG2 channels are still downrezzed.All reports indicate the Direct is running at full resolution now.
nobody is broadcasting is 1080p. Nor will they be any time soon.
Come on!.I guess I should clarify it to state that they are running at a true HD resolution and good bit rate rather than HD Lite
I thought maybe you meant at the original quality level that the individual broadcaster provides it to Dish; that is, Dish simply does a pass-through (if that's possible).
I would rather watch a sporting event, aka football in 720p anyday. Too much pixelation watching fast movements in 1080i. I hate watching the CBS ota NFL broadcasts.
Then your CBS sucks then.....I dont have that issue. Our CBS blows everyone out of the water...No sub-channels full bitrate and sound.
Come on!.
Which resolutions do you claim are true HD resolutions? And how many bits is a good rate?
Right.Sure, it is possible, but NOBODY does a "pass-through." Not DiSH. Not DirecTV. Not even your local cable company. ....
My TV does fine on 1080i sports. Just not on a couple of the bit starved ota's I have.
Sure, it is possible, but NOBODY does a "pass-through." Not DiSH. Not DirecTV. Not even your local cable company. Not even FIOS or uVerse. Everyone transcodes into a different bitrate and sometimes a different resolution. The marketing and "word-of-mouth" marketing is trying to convince people that FiOS is not compressed so you should buy FiOS instead of satellite. It's simply not true in any form.
In addition, the myth that OTA HDTV is not compressed is also false--ATSC always uses MPEG2 compression. Sure, its quality is higher than what you see on the satellite, but it is still compressed, and that compression constantly varies because statistical modulation is used among the HDTV stream and the 3 or 4 "subchannels" on that ATSC channel, constantly varying the bitrate.
