aboali, note the directions (125 degrees, etc) and distances. NBC, FOX, and PBS are all broadcast from the same set of towers. CBS and PAX come from another set of towers. Receiving PAX is probably a matter of a minor adjustment of the antenna. ABC is broadcast from a completely different direction- neither the stealth nor the sensar antennas will pick this up, unfortunately (although the sensar is bidirectional, this station is coming from just the wrong angle). WB is on the same tower as CBS, but since it is listed in the violet range, I suspect they are broadcasting at very low power- that should change as the station becomes more popular in your area. Final analysis: If you want PAX and ABC, ask Voom to upgrade your antenna to an omni-directional antenna rated for the lt green range (to be safe), and make sure the installer spends the time to adjust it for all channels- even an omni-directional antenna needs to be placed just right. If you want WB, try it during primetime hours (I'm sure they increase the output then) and be patient.
