Will a 6000 work with a Dish 1000 ?
Thailog
10
I currently have 2 301s and a DP 500. I am going to replace one of the 301s with a 6000 receiver so I can get the HD content. I was also going pick up Dish 1000 so I can get the 3 birds.
I have heard that one 301 receiver is enough to power a dish pro system, whatever that means. But, My question is, will the Dish1000 work with the 6000? If not what else do I need to make this setup (a 301 and a 6000) work? I'd prefer a single dish solution if at all possible.
The 6000 receiver will work with the Dish 1000, but I would get the 811 reciever for HD instead. The 811 is more modern than the 6000 and you may also have to get a DP adapter for it.
I already have the 6000. I'd rather not buy another HD receiver thats going to end up having to be replaced anyway when Dish goes to Mpeg4.
So a DP adapter is all I need?
The Dish1000 ships with a DishPro Plus Twin LNBF and a DishPro Single or Dual LNBF. As long as you have at least one DishPro receiver connected to the dish, you can have a legacy receiver connected to the other port. No DishPro adapter is required. Some legacy receivers are not compatible with the 129 satellite. The model 6000 is compatible.
Thanks ATS
P303 Skips
Two Questions. Existing sub q and HD expansion
