Is it possible to use my wifi usb adapter on my Ultra to use for internet?
I use it on one of my laptops for internet.
I don't think the device will be recognized unless the drivers are preloaded, and waiting for the device to go active. That will take some work, I suspect.
Drivers aren't preloaded in Linux but the drivers are present in a modules directory. The kernel loads them only when the device is present.
I worked on getting one to work with my former Azbox Elite, once the ethernet port got smoked somehow. Since the Azbox Premium uses realtec drivers, I was looking for a usb stick with a realtec chipset. I tried several with no results. Later I found a post on a German forum telling how to set it up, first copying the drivers to the DOM drive on the Elite, and then setting up scripts to load the drivers.
Apparently it can be done, but it's not simple.
This may yield a clue, List of wireless adapter that work on Azbox HD Elite .
its not coded into the firmware... your simply getting into advanced topics. definately not plug and play. these files will give you a start. sorry but they arent in english. when i find the orignal post ill post more info...
use at own risk. i havent tried them.
crackt out,.
[B]Wlanmonitor -Plugin for Azbox HD[/B]
[B]08.12.09[/B]
This plugin is for fans with Wi-Fi Azbox thinking elite, who want only occasionally connect to the network.
1. You can download from a list of the best wireless drivers, perform various tests and connect to the wireless network, all with the remote PC is needed only for one-time configuration.
2. Two new drivers for rt73 sticks with zd1211-to-chip and chip available, both with WEP/WPA/WPA2.
3. Scan function to see not only access points, but also other wireless clients, because the drivers control the monitor mode.
One can also do everything via a telnet connection from a PC, but herewith it is more convenient, quick time to play around in a commercial break something.
At least one of the internal driver (RT2870) for Azbox premium can be placed in the monitor mode. Whether the scan but it works, I can not test.
The installation of the plugin requires approximately 80k, wlanmoni.zip (holger.heit, 24.5 kB - 0 downloads)
to the driver rt73_m (370k) and zd1211 (390k), driver.zip (holger.heit, 305.3 kB - 0 downloads)
is a compatible with the zd1211 wpa_supplicant with EAP support at about 350k,
to scan the program about airmon 50k (a defused airodump). progs.zip (holger.heit, 153.7 kB - 0 downloads)
Who's right stick and wants to try everything, even time takes about 1 MB on a box, and can therefore be set in the configuration file, a path to drivers and additional programs. In my case a USB memory stick is connected to wlan with a directory from the path / DATA/usb1/sda1/wlan is.
Install the plugin as usual USB or / tmp.
Then an ftp connection between PC and azbox in the configuration file / PLUGINS / WLANmonitor / wlanmoni.cfg adjust the path and copy unzipped drivers and programs on this path. Now check whether the programs wpa_supplicant airmon and after unpacking and copying are still feasible, and finally
- Adjust for WFP in the configuration file entry KEY, the hidden SSID SSID in addition to the entry,
- Customize with rt73 and WPA/WPA2 PSK entry in the configuration file,
- For the zd1211 and WPA/WPA2 files userscript0.sh (path to wpa_supplicant) and adjust wpa1.conf (ssid and psk).
Windows users can do very well with winscp, as well as an appropriate editor is included.
Within the plug-in, one moves up down with the arrow keys / or the red / blue function key to move between tabs, selection of options with the arrow keys left / right, do something with OK button and exit with EXIT button. A short manual wlanmoni.rtf is contained in wlanmoni.zip.
To test a level_one WNC_0301 V3 (rt73 chip was from ralink) and a fiber line WL410U (zd1211 chip used by ZyDAS).
There are many Wi-sticks with the ZyDAS chips, which have excellent reception characteristics, much better than ralink.
The program is not guaranteed accurate, but perhaps useful for others.
we may see e2 for the azbox first. haha.
